Lathe - Spindle Motor Stabilizer - Installation - AD0726
Service Home How To Procedures Lathe - Spindle Motor Stabilizer - Installation - AD0726
Recently Updated Last updated: 11/20/2023
AD0726
- Jump to Section - 1. Introduction 2. Installation (4 steps) 3. Verification (1 step) Back to Top
This procedure shows how to install a spindle motor stabilizer bracket.
Machine Compatibility:
  • ST-35Y
  • 93-3706 SPINDLE MOTOR STABILIZER ST-35Y
Push [POWER OFF].
Remove the coolant collector [1] to gain access to the spindle motor.
Install a washer (4) [1] onto each motor stud.
Install spindle dampening bracket [2] onto motor studs.
Note: The bracket side slots align [3] with the enclosure PEM nuts.
Install a washer (4) [4] and nut (4) [5] onto each motor stud. Tighten nuts down.
Attach 8" long foam strips on the top [1] of the coolant collector and the 22" long foam strips on the bottom [2] of the coolant collector.
Install coolant collector back onto the machine.
Verification
Once the installation is complete, run a program with deep cuts to verify the kit has improved spindle vibration issues.
Note: Running the same program that caused the vibration alarm previously is a good way to verify improvement.
For more troubleshooting information on Lathe spindle vibration, refer to the Spindle – Lathe  – Troubleshooting guide.
