Molex Connector - Change Pin Locations
Service Home How To Procedures Molex Connector - Change Pin Locations
Recently Updated Last updated: 06/13/2023
- Jump to Section - 1. Introduction (1 step) 2. Pin Extraction/Re-Pinning (3 steps) Back to Top
The following service video shows how to properly remove the pins from a Molex connector.
  NOTE:  This  service video is for reference only and does not replace the written procedure.
Do this procedure to change the location of the pins in a Molex connector. This procedure includes these tasks:
1. Disconnect a pin [3] from one location [5] in the Molex connector.
2. Connect the pin [3] in another location [5] in the Molex connector.
The image shows the following:
  1. Molex connector
  2. Molex extraction tool
  3. Pin(s)
  4. Slots for the extraction tool
  5. (4) locations on the Molex connector
NOTE: The Molex - Extraction Tool is not provided/supplied by Haas. The extractor tool can be purchased from Molex, part number 11-03-0044.
CAUTION: Do not try to change the pin locations with a different tool. This can cause damage to the pins.
Put the extraction tool [2] into the Molex connector [1]. Use the slots [4] on the sides of the Molex connector location [5] for the extraction tool.
CAUTION: Make sure you use the slots [4] when you put the extraction tool into the Molex connector. This prevents damage to the tool and pins [3].
When you put the extraction tool [1] into the slots, the lock tabs [2] fold down [3].
NOTE: When the lock tabs fold down, this lets you pull the pin out of the Molex connector.
Pull the pin out of the Molex connector.
Inspect the lock tabs [2] for damage. Damaged lock tabs are a cause of connector failure.
Put the pin [1] into the correct location of the Molex connector.
Make sure the location of the pin [1] is the same as the location of the pin [3] for the adjacent Molex connector [2].
