Side-Mount Tool Changer - Z-Axis Tool Change Offset - NGC
Service Home How To Procedures Side-Mount Tool Changer - Z-Axis Tool Change Offset - NGC
6.1 Side-Mount Tool Changer - Z-Axis Tool Change Offset - NGC
Recently Updated Last updated: 08/13/2025
Revision A - 08/2025
 Note: This procedure also applies to the HSK-A63.
Power on the machine with your Haas Control Key.
Set the grid offsets, refer to NGC - Axis Grid Offset.
Push [ZERO RETURN].
Push [ALL].
Place a tool holder into the double-arm.
Mount a 0.0005" indicator [2] and mag-base to the machine table.
Place the indicator tip on the bottom [1] of the toolholder [3].
Set the indicator to 0.
Jog the table away from the toolholder.
Do not move the indicator.
Move the toolholder from the double-arm to the spindle.
Jog the table to position the indicator under the toolholder.
Do not hit the spindle with the indicator.
Jog the Z Axis up or down until the indicator goes back to zero.
Push [DIAGNOSTIC].
Navigate to the Factory tab in the Parameters tab.
Type 3.078 and push [F1].
Push [F2] Set Z Axis Tool Changer Offset.
The Z Axis Tool Changer Offset Done prompt appears.
Set the spindle orientation offset, refer to NGC- Side-Mount Tool Changer - Spindle Orientation Offset.
Note: For HSK-A63 spindle, refer to Side-Mount Tool Changer - HSK - Spindle Orientation Offset - NGC
Do several tool changes to test the tool changer operation.
Note: After you do this procedure, inform the customer they need to reset their tool length offsets.
