Pendant - Carbon Fiber - Replacement - AD0789
Service Home How To Procedures Pendant - Carbon Fiber - Replacement - AD0789
- Jump to Section - 1. Introduction 2. Removal (4 steps) 3. Installation (3 steps) Back to Top
Recently Updated Last updated: 07/18/2024
Revision 1
AD0789
This procedure explains how to replace the standard bezel with a carbon fiber bezel and how to remove the current glove box door for the carbon fiber option.
Required Materials:
  • 06-0536 Bezel
  • 06-0537 Glove Box Door
Required Tools:
  • Flathead Screwdriver or Putty Knife
  • Torx T25 Screwdriver
  • 3/32 Allen Wrench
Removal
Remove the front panel from the control pendant assembly.
Use a putty knife or a small flathead screwdriver to carefully remove the glove box liner.
Remove screws [1] from the glove box flange to release the gas spring.
Note: Gas springs are attached to the brackets by a roll pin, which do not need to be removed during the removal process.
Remove the six screws from the glove box door.
Note: Lower right and lower left screws secure the door hinge to the glove box door brackets.
Note: Each gas spring and bracket will detach as one whole piece. Do not separate the two.
Install the new carbon fiber front panel.
Install gas springs back into the glove box flange [1].
Install carbon fiber glove box door by inserting the removed screws that attach the brackets and door hinge.
