Simulator - Audio Amplifier PCB - Replacement - NGC - AD0443
Service Home How To Procedures Simulator - Audio Amplifier PCB - Replacement - NGC - AD0443
Recently Updated Last updated: 03/11/2019
AD0443
- Jump to Section - 1. Introduction 2. Replacement 3. Test Back to Top
This procedure will show you how to replace the Audio Amplifier PCB on a NGC simulator.
This document applies to the following kit:
  • 93-7540 Service Kit, Simulator Audio Amplifier PCB
Replacement
Turn off the simulator and remove the power plug.
Remove the back cover [1].
The audio amplifier PCB is located on the bottom of the simulator near the speaker.
Disconnect the audio input [2], power [3] and speaker [4] cables from the audio amplifier PCB.
Squeeze the 4 retaining tabs [5] to remove the audio amplifier PCB.
Install the audio amplifier PCB and connect the audio input, power and speaker cables.
Note:  Make sure the speaker wires [4] are installed with the correct polarity.  The red wire is positive (+) and the black wire is negative (-).
Set the volume knob [6] to the half volume position.  To find the half position, rotate the volume knob all the way to the left then all the way to the right and then set it to the half position.
Test
Plug in the power to the simulator and press [POWER ON].
Once the simulator has finished it's boot process.   Press [ALARMS] . Go to the Alarm Viewer [1] tab.
Search for 151 [2].  Alarm 151 has a help video that can be played to test the audio.
Press [HELP] [3].
Press [F3] [4] to play the video.
Make sure there is sound and that is free from distortion.
Install the simulator cover.
