SR - Cable Carrier - Opening - AD0965
Service Home How To Procedures SR - Cable Carrier - Opening - AD0965
12.6 SR - Cable Carrier - Opening
Recently Updated Last updated: 04/21/2026
AD0965
Revision A - 04/2026
This procedure will show you how to open the cable carrier cover links for the SR machines.
Opening Cable Carrier
Use a small flat head screwdriver to push in through the right hole slot on the cable carrier cover link and pry up lightly on that side as shown in the picture.
On the left side of the cover, using the same technique, use the flat head screwdriver to lightly pry up the cover.
The cover link should look like this after prying up on both sides.
Lightly pull up on to the pried up side of the cable carrier cover link and slide it out of the cable carrier.
Repeat the steps above to take off as many cable carrier cover links as needed.
Putting On Cable Carrier Cover Links
The cable carrier link covers need to put back into the cable carrier in the correct orrientation.
The curved portion of the cable cover link cover needs to be tucked under the cover link that comes before it.
The clips on the cover link should line up with the extrudes on the cable carrier link.
Once they are lined up, push the link cover back into place.
