SR-P - Vacuum Soft Start Breaker - Installation - AD0962
Service Home How To Procedures SR-P - Vacuum Soft Start Breaker - Installation - AD0962
12.5 SR- P - Vacuum Soft Start Breaker - Installation
Recently Updated Last updated: 04/16/2026
AD0962
Revision A - 04/2026
This procedure will show how to install the soft start breaker for your SR-P machine.
SR-P machines that are having vacuum pump or soft starter issues and did not come with the soft start breaker installed on the machine are recommended to order the following the service kit. This kit is also a one to one replacement for SR-P machines that need to replace their soft start breaker:
This procedure applies to the following service kit:
  • 93-5828 SR-P VACUUM PUMP BRKR KIT
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Disconnect and remove the original din rail and soft starter from the electrical cabinet.
Install the new five inch din rail [1] onto the sub-spindle servo amp fan bracket assembly using the two provided PPHS 10-32 screws.[2]
Slide on the first DIN rail end cap [1] onto the DIN rail.
Slide on the soft start breaker [2] from the service kit onto the DIN rail.
Next, slide on the soft start [3] onto the DIN rail next to the soft start breaker.
Finally, slide on the second DIN rail end cap [4] onto the DIN rail to secure the breakers and softer starter.
Connect cable 33-1595 T1/T2/T3 K1-SS [1] from the M1 contactor to the soft start breaker.
Connect cable 33-1618 SR SS TO BRKR CBL 2FT [2] from the soft start breaker to the soft starter.
