Trunnion MRZP - Rotary - How to Procedure - AD0810
Service Home How To Procedures Trunnion MRZP - Rotary - How to Procedure - AD0810
2.11 Trunnion MRZP
Recently Updated Last updated: 05/06/2025
Trunnion MRZP Setup
AD0810
The Machine Rotary Zero Point (MRZP) Offsets are control settings that define the centers of rotation for the rotary table relative to the home positions of the linear axes. This program can be used to obtain MRZP values for any rotary axis, A, B or C.
Required parts
  • 93-2880 MRZP MASTER TOOL KIT W/O PROBE&PULL STUD MRZP kit
  • Wireless Intuitive Probing System
Machine Requirements
  • Software 100.20.000.1200 or higher
Instructions
Place the spindle probe in the spindle.
The spindle probe must be calibrated before the probing cycle is started. If it has not been calibrated do so before continuing.
The steps to calibrate a probe can be found at Wireless Probing How-To PART 1 - Calibrating the System.
Press [EDIT] then navigate to the VPS tab.
Then highlight PROBING directory and press right arrow.
Highlight the CALIBRATION directory and press the right arrow button.
Highlight the MRZP Calibration directory and then press the right arrow button.
Highlight Trunion MRZP and press  [ENTER].
Select the model to the coresponding rotary and press [ENTER].
Select the corresponding platter option.
Jog the spindle to the center bore of the rotary axis.
Note: Each jog postion correlates to its respective platter option.
Once completed press [F4] to run the cycle.
Once the cycle has been completed press [Current Commands] and highlight the Macro Variables Tab.
Locate and write down MRZP Marco Variables 10,300 to 10,305.
Note: These variables will be used as the the MRZP offset values.
Use the written down MRZP Macro Varibales and insert them into settings 300 to 305.
