Vector Drive - Intake Filter - Installation - AD0097
Service Home How To Procedures Vector Drive - Intake Filter - Installation - AD0097
13.3 Vector Drive - Intake Filter - Installation
Recently Updated Last updated: 01/31/2022
AD0097
Applies to machines built from: January, 2007
This procedure tells you how to install the intake filter [1] for the vector drive.
KIT PN: 93-2185    FILTER, VECTOR DRIVE INTAKE KIT
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Clean the electrical cabinet door around the vector drive air intakes with alcohol.
Put the GASKET [B] on the FILTER POCKET [A].
Remove the paper [1] that covers the adhesive on the GASKET [B].
Attach the top hook of the FILTER POCKET [A] to the bottom edge of the upper door vent opening [2].
Press down on the edges [4] of the FILTER POCKET [A] to attach it to the electrical cabinet door.
Note: Make sure that the coarse side of the VENT FILTER [C] (the side with the pull tab [3]) faces out.
Insert the VENT FILTER [C] into the frame until it clips into place.
Filter Maintenance
  1. Check the filter at regular intervals for dirt.
  2. Remove the filter from the frame.
  3. Clean the filter with warm soapy water and a soft brush.
  4. Rinse the filter with warm water and dry it.
  5. Insert the filter into the frame until it clips into place.
    Note: Make sure that the coarse side of the filter (the side with the pull tab) faces out.
