Chip Conveyor - Types and Use Cases - RD0096
Service Home Chip Conveyor - Types and Use Cases - RD0096
8.1 Chip Conveyor - Types and Use Cases
Recently Updated Last updated: 04/06/2026
RD0096
Revision B - 05/2026
Different Conveyor Types
Belt-Type Conveyor (Standard)
Chips and Coolant Conveyor. Product of Haas CNC machine tools.
Description:
  • Heavy-duty steel belt-type chip conveyor
  • Activated via M-code, or from the control pendant
  • User settings to control cycle interval and duration for automatic operation
  • Automatically reverses if a jam occurs
  • Automatic operation increases energy efficiency
  • Lift angle minimizes coolant carryout
  • Discharges at standard barrel height
Filtration Conveyor
Description:
  • Built-in filtration system
  • Heavy-duty steel chip scraper
  • Automatic reversal upon torque overload situations
Chip-Disc Filter Chip Conveyor
Description:
  • Same features as the belt-type conveyor plus more
  • Built-in disc filtration system 24 mesh disk filter keeps the coolant tank free of chips and debris
  • Integrated backwash system keeps chips on the belt for proper evacuation to chip hopper or barrel (includes additional pump)
    • Backwash system requires continous opertation.
  • Debris-free coolant for better TSC performance
Use Cases of Each Conveyor Type
Belt-type Conveyor (Standard)
  • Works well for all applications
  • Good for coarse large chips with a lot of chip build up
  • Smaller chips may end up inside conveyor or float out with the coolant into the chip tray
  • More daily maintenance of chip tray
  • Not recommended for unattended operation where fine chips are present
Filtration Conveyor
  • Great for smaller chips sizes
  • Filter box collects small chips and keeps them from going back into coolant tank
  • Tailored for machines that are doing finishing operations
  • Scrapping off the bottom means that chips must sink and not float in order to be shuttled out
  • A number of thick stainless steel brushes scrape along the surface of the conveyor filter box to keep the coolant pathways open and maintain proper coolant flow
  • Does not handle solid pieces of material in the conveyor, jamming may occur
Chip-Disk Filtration Conveyor
  • Great for all applications especially instances where less chip maintenance is desired such as unattended operation
  • Has all the same advantages as belt-type
  • The chip-disk filter strains the coolant and keep the small fine chips  from going to the chip tray
  • Good for automation machines which would otherwise need to clear the chip tray consistently
  • Requires continuous operation to ensure proper coolant filtration and flow
