Coolant Sanitizer - Operation - RD0082
Service Home Coolant Sanitizer - Operation - RD0082
21.3 Coolant Sanitizer - Operation
Recently Updated Last updated: 10/24/2025
RD0082
  1. Charge the battery
    • Plug the timer into a regular 120V outlet
  2. Reset the timer
    • Press [REST] after chargeing to clear any data in memory.
  3. Set the date and time
    • Press [SET] for 2-seconds until "MO" for Monday begins to flash. Press [UP] or [DOWN]  to select the day of week.
    • Press [SET] to advance to the "Hour" and "Minute" setting.
    • Press [UP] or [DOWN] one more time to complete setup.
    • To reset the current time, repeat the steps above.
  4. 12/24 hour mode
    •  Note: The time on the system is by default 24-hour mode.
    • Press [CD] and [SET] simultaneously to change to 12-hour mode, "AM" will be in display.
  5. Daylight Savings time
    • Press [MANUAL] and [SET] simultaneously to add 1-hour for Daylight Savings and "S" will appear in the display. To set it back, press the two buttons simultaneously and "S" will disappear in the display.
  6. Program Timer
    • While in clock display, press [UP] once to display the first ON Setting 1ON--:--.
    • Press [SET] once, the "MO" will begin to flash, press [UP] or [DOWN] to select the day of the week or combination of days for this program.
    • Press [SET] again to advance to the "Hour" setting. Press [UP] or [DOWN] to select. Repeat this step for the "Minute" setting.
    • Press [SET] to complete the program setting.
    • Repeat the procedure 2-5 to create the OFF setting.
    • Repeat steps 1-7 for additional ON/OFF program settings.
    • Press [UP] and [DOWN] simultaneously to exit program setting mode.
Important : The coolant sanitizer uses an Ozone Emitting Device and should be used in a well ventilated area.
Note : This information can also be found on the decal located on the front of the Coolant Sanitizer box.
Important : The coolant sanitizer requires the machine to be on or the use of a 120V outlet to supply power to the submersible pump and function properly.
