ST-Series Machine Version - Identification - RD0061
Service Home ST-Series Machine Version - Identification - RD0061
- Jump to Section - 1. Introduction 2. ST Lathe Reboot Version 3. ST-40/45 Series Lathe Reboot Spindle Head Castings 4. ST Lathe Non-Reboot Version Back to Top
Recently Updated Last updated: 10/17/2025
RD0061
Revision A - 06/2025
Within recent years Haas Automation has made design updates to the ST lathe machine models (ST-1X, ST-2X, ST-3X, ST-4X). Some but, not all parts are interchangeable between older machines and their redesigned counterparts.
To identify which iteration of these machine models you are dealing with, look for the following key identifying features below.
Reboot ST Lathes (current version) have a "square" door and enclosure. All sheet metal bends are 90°.
ST-40/45 Series Spindle Head Casting Versions
Within in the ST-40/45 Series Lathe Reboots, there are two versions of castings. It is important to identify which one applies to the machine.
Note: The access panel can be removed on the spindle enclosure side to reveal the spindle head casting.
The Spindle Head Casting [1] is seen in ST-40/45 Series Lathes with built dates before or in 2023.
The Spindle Head Casting [2] was introduced in ST-40/45 Series Lathes in 2023.
Since there were ST-40/45 Series Lathe machines that were built with both designs in the same year, it is crucial to identify which spindle head casting applies to each machine. This will help serviceability of your ST-40/45 Series Lathe machine in the future.
Non-Reboot ST Lathes have a partially angled door and enclosure.
