Additional Haas Axis Lubrication Oil Conversion Kits Available
Service Home Service Alerts/News Additional Haas Axis Lubrication Oil Conversion Kits Available
February 10, 2023 Additional Haas Axis Lubrication Oil Conversion Kits Available
Machines with the Red Grease system can now convert to Haas Axis Lubrication Oil (HALO) by ordering kit #93-2755A and refer to the Red Grease to HALO Conversion procedure. Lathes will also need to add an extra check valve and nipple fitting to the X-Axis and the Y-Axis if it has one. Every Lathe will need to order at least one (1) of kit 93-3610, lathes that also have a Y-Axis will need to order two (2) of kit 93-3610.
Machines with HLG that have the old plastic reservoir can upgrade to HALO with a metal reservoir by ordering kit #93-2601B and refer to the HLG Plastic to Metal Haas Axis Lube Oil (HALO) Reservoir procedure. Lathes will also need to add an extra check valve and nipple fitting to the X-Axis and the Y-Axis if it has one. Every Lathe will need to order at least one (1) of kit 93-3610, lathes that also have a Y-Axis will need to order two (2) of kit 93-3610.
Once machines have been converted to Haas Axis Lubrication Oil, PN 93-3584A: AXIS LUBE OIL REFILL 1 GALLON can be ordered to refill the lubrication canister. Refer to the Haas Axis Lubrication Oil - Reservoir Refill procedure for refilling the lubrication canister.
Note: The ordering of 93-2755A or 93-2601B will include a patch for NGC machines that will be associated to the machine records upon ordering. This patch needs to be installed by a Service Engineer. Please know that the patch does not need to be immediately installed in the control when the customer installs the conversion kit. It can be installed in the control during the next service visit as noted in the installation instructions for the customer.
The patch changes the parameter for the frequency of oil distribution when the machine is at idle. There will be no significant change in oil usage by waiting for a Service Engineer to install the patch. The customer will need to change Setting 277, Axis Lubrication Interval. This setting is for the frequency of oil distribution when the machine is in motion. Not changing this setting will significantly effect the oil usage.
