ST-45S Install
PRE-INSTALLATION [GUIDE]
ST-45S Install
    CNY ONLY
CNC Short-Bed Lathe with 30" x 28" max capacity and 7.0" bore
  • 18" (opt) Chuck Size
  • 7.0" Bar Capacity
  • 1.4k RPM
  • 40 hp Power
  • Layout Drawing
  • Lifting Instructions
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, heavy and complex machines, such as Large-Frame mills and UMCs, may require a 12" (300 mm) concrete foundation, to ensure accurate geometry. Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
For best cutting performance, Haas recommends anchoring your machine. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
IMPORTANT: Most – but not all* – Haas machines may be lifted by overhead crane for positioning and installation. Depending on the model, your new Haas machine may have built-in lifting provisions, or may require a lifting kit, available through your local Haas Factory Outlet (HFO), that includes required lifting brackets and hardware.
Refer to the lifting placard on the rear of the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the rear of the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
*GR, GM, TL, CM, and CL models are not suitable for overhead lifting. They must be lifted by forklift.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 1400 rpm 1400 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Spindle Power 40.0 hp 29.8 kW
Domestic Pallet 216.5 in x 94.5 in x 116.0 in 550 cm x 240 cm x 295 cm
Export Crate 216.5 in x 96.0 in x 120.0 in 550 cm x 244 cm x 305 cm
Weight 20400 lb 9253.0 kg
Optional Spindle
SPINDLE SPINDLE DRIVE PEAK (HP/KW) CONT (HP/KW) INPUT AC VOLTAGE FULL LOAD AMPS
Extra-Performace Spindle Gearbox 55/41 30/22.4
220 (3 Phase)
440* (3 Phase)
105
53
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine's electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1, and CM-1.
Ground
Three-Phase Power
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
