ST Lathe Installation - NGC
Service Home How To Procedures ST Lathe Installation - NGC
3.1 Lathe - Installation
Recently Updated Last updated: 02/22/2024
ST Lathe - Installation - NGC
Revision E - 06/2026
This procedure shows you how to install an ST Lathe.
Tools required:
  • Precision Machinist Level, 0.0005" Division
  • T-2181A CNC Dual Leveling Tool
To identify if you have a reboot machine, refer to: ST-Series Machine Version - Identification
Leveling Screws Hardware
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Remove Rust Inhibitor
To safely and effectively remove rust inhibitor from way covers and other non-painted surfaces:
Initial Scraping
  • Use a plastic scraper to remove the bulk of the rust inhibitor.
  • Avoid using metal tools to prevent scratching or damaging the surface.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers.
Chemical Cleaning
  • Spray the affected areas with a heavy-duty citrus cleaner or Simple Green.
  • Ensure full coverage of all non-painted surfaces coated with rust inhibitor.
Soak Time
  • Allow the cleaner to soak for several minutes to loosen remaining residue.
Wipe Down
  • Use a clean shop towel to thoroughly wipe off the softened rust inhibitor.
Rust Proofing
  • Apply mineral spirits or WD-40 to all exposed metal surfaces to prevent future rust formation.
Important: Always wear gloves and eye protection when handling chemical cleaners. Dispose of used towels and cleaning agents according to local environmental regulations.
 Important: To avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Rust Inhibitor - Safety Data Sheet (SDS)
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
Electrical Installation
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
Shipping Brackets Removal
Updated
For ST-10-35 Series Machines and DS-30Y Lathes
Remove the turret to casting shipping bracket [1].
Remove the control panel shipping shoulder bolt [2]. Machines with pendant cabinet will have the shipping bracket to the right side of the control.
Remove the door shipping shoulder bolt [3].
Remove the chip conveyor shipping brackets [4]. Plug the threaded sheet metal holes with the shipping bracket screws.
For Pre-reboot ST-30/35/DS-30Y Lathes
Remove the control panel shipping shoulder bolt [1].
Remove the turret to spindle shipping bracket [2].
Remove the Y-axis shipping bracket [3].
Remove the door shipping bracket [4].
Remove the second spindle shipping bracket [5]. See DS Shipping Bracket Removal AD0065.
Remove the chip conveyor shipping brackets [6].
For Pre-reboot ST-40/40L/45/45L/50/55 Lathes
Remove the door shipping brackets. For ST-40/45 there is one bracket. For ST-40L/45L/50/55 there are two brackets [1,2].
Remove the turret to spindle shipping bracket [3].
Install the pendant to the machine.
For a guide on how to install the pendant please see:
ST-40/45/50/55 - Pendant - Installation
For ST-40-55 Series Reboot Machines and DS-40Y Machines:
Remove the door shipping shoulder bolt [1].
Remove the control pendant shipping bracket [2].
NOTE: To identify ST- Lathes pre-reboot from reboot machines, see the ST-Series Machine Version - Identification.
Updated
For DS-40Y Machines:
Remove the Secondary Spindle shipping bracket[1].
ST-10/10Y/15/15Y Leveling
Zero return each axis one at a time or press [POWER UP]. Go through the leveling process.
Repeat these steps to achieve correct machine level.
Set the machine height using the four corner leveling screws to 3.0" above the floor. Turn each screw so they have equal tension.
Raise screw 2 so it is off the pad.
Move the tailstock or second spindle to its home position.
Mount tool T-2181A onto turret so that it is parallel to the ground.
Jog the turret to center of X-axis then jog turret towards spindle on Z-axis as far as possible.
Look at the smaller level that is parallel to the Z-axis and raise or lower screw 4 to center the bubble.
Now look at the larger level that is parallel to the turret face and raise or lower screw 1 to center the bubble.
To check for twist in the machine move the turret along the Z-axis back to home position.
Using the larger level raise or lower screw 2 to center the bubble and wait 10 seconds for the bubble to settle.
Move the turret back towards the spindle as far as possible and raise or lower screw 1 to center the bubble. Continue moving the turret from the home position to the spindle and adjusting screws 1 and 2 until the twist is removed.
Tighten the locking nuts making sure that you do not raise or lower the screws.
Verify that the machine is level by moving the turret along the Z-axis and checking for twist and continue adjusting until level.
ST-20/20Y/25/25Y Leveling
Zero return each axis one at a time or press [POWER UP]. Go through the leveling process. Repeat these steps to achieve correct machine level.
Note: If your machine has a BMT turret install a BMT65OD-1 tool holder[1] to pocket 1. Assemble T-2181A[2] so the level is parallel to the floor. There are three slots depending on the wedge angle of the machine. Use the tool holder to clamp the level or use the jack screws to fix the level in the tool holder.
Raise screws 2 and 4 so they are off the pads.
Jog turret to center of X-axis then jog turret towards spindle on Z-axis as far as possible.
Look at the smaller level that is parallel to the Z-axis and raise or lower screw 5 to center the bubble.
Using the larger level raise or lower screw 2 to center the bubble and wait 10 seconds for the bubble to settle. .
Move the turret back towards the spindle as far as possible and raise or lower screw 1 to center the bubble. Continue moving the turret from the home position to the spindle and adjusting screw 1 and 2 until the twist is removed.
Lower screw 4 onto the pad by hand and use a wrench and tighten only by 10°.
Do not tighten any further as you will change the level of the machine.
ST-30/30Y/35/35Y/40Y and DS-30Y/40Y Leveling
 Note: If your machine has a BMT turret install a BMT OD-1 tool holder[1] to pocket 1. Assemble T-2181A[2] so the level is parallel to the floor. There are three slots depending on the wedge angle of the machine. Use the tool holder to clamp the level or use the jack screws to fix the level in the tool holder.
Raise screws 2, 3, and 5 so they are off the pads.
Look at the smaller level that is parallel to the Z-axis and raise or lower screw 6 to center the bubble.
Using the larger level raise or lower screw 3 to center the bubble and wait 10 seconds for the bubble to settle. .
Move the turret back towards the spindle as far as possible and raise or lower screw 1 to center the bubble. Continue moving the turret from the home position to the spindle and adjusting screw 1 and 3 until the twist is removed.
Lower screws 2 and 5 onto the pads by hand and use a wrench and tighten only by 10°.
ST-40/40L/45/45L/50/55 Leveling
Raise screws 2, 3, 4, 6, and 7 so they are off the pads.
Look at the smaller level that is parallel to the Z-axis and raise or lower screw 8 to center the bubble.
Using the larger level raise or lower screw 4 to center the bubble and wait 10 seconds for the bubble to settle. .
Move the turret back towards the spindle as far as possible and raise or lower screw 1 to center the bubble. Continue moving the turret from the home position to the spindle and adjusting screw 1 and 4 until the twist is removed.
Lower screws 2, 3, 6, and 7 onto the pads by hand and use a wrench and tighten only by 10°.
Lubrication Verification
Run the spindle run-in program.
 Note: For 10K spindles and above use a balanced tool holder
Examine the sight glass, make sure the correct number of drops are fall through the sight glass.
Examine the fittings [1,2] on top of the oil pump tank.
The oil collects on top of the oil pump tank [3] either behind or in front of the sight glass bracket, underneath the leaking fitting.
Tighten any leaking fittings.
Go to the Maintenance tab.
Press [F2] to cycle an axis lubrication test.
Inspect the gauge on the lubrication system.  Make sure it holds pressure.
Machine Operation
Updated
Test Coolant Operation - Multi-Stage Coolant Pump
If your machine comes equiped with the Multi-Stage Coolant Pump, conduct the following operation:
  • Ensure the hose fittings to the Multi-Stage Coolant Pump are connected and secure.
  • Run coolant by pressing  [COOLANT] on control pendant.
  • Check for leaks around the coolant pump and hose connections.
Updated
Test High Pressure Coolant (HPC) Operation
If your machine comes equiped with the High Pressure Coolant system, conduct the following operation:
  • In [MDI] command: M88; G04 P10.; M89;
  • Verify that the HPC pump motor turns on.
  • Check for leaks at the coolant manifold and hose fittings.
Auxiliary Coolant Filter Installation
  • If your machine includes the Auxiliary Coolant Filter option perform the installation procedure
For a guide on how to perform the Auxiliary Coolant Filter installation procedure please see:
Chips and Coolant- coolant refill. Product of Haas CNC machine tools.
Coolant Refill Calibration
  • If your machine includes the Coolant Refill option perform the calibration procedure.
For a guide on how to install and perform the Coolant Refill calibration procedure please see:
Oil Skimmer Installation
  • If your machine includes the Oil Skimmer option perform the installation procedure
For a guide on how to perform the Oil Skimmer installation procedure please see:
Cabinet Cooler Installation
  • If your machine includes the Cabinet Cooler option perform the installation procedure
For a guide on how to perform the Cabinet Cooler installation procedure please see:
Chips and Coolant Excel Exhaust. Product of Haas CNC machine tools.
Enclosure Exhaust Installation
  • If your machine includes the Enclosure Exhaust option perform the installation procedure
For a guide on how to perform the Enclosure Exhaust installation procedure please see:
24V Magnetic Worklight Installation
For a guide on how to perform the Magnetic Worklight installation procedure please see:
Lathe 24V Magnetic Worklight Installation
Chip Conveyor Installation
  • If your machine includes the Chip Conveyor option perform the installation procedure
For a guide on how to perform the Chip Conveyor installation procedure please see:
Test Chip Conveyor
  • Test the chip conveyor by pressing the [CHIP FWD],  [CHIP STOP], and [CHIP REV] buttons on the control pendant
Remote Jog Handle Color Installation
  • If your machine includes the Remote Jog Handle Color option perform the installation procedure
For a guide on how to perform the Remote Jog Handle Color installation procedure please see:
RJH-C Installation
Remote Jog Handle Touch Installation
  • If your machine includes the Remote Jog Handle Touch option perform the installation procedure
For a guide on how to perform the Remote Jog Handle Touch installation procedure please see:
RJH-T Installation
13
Test the Door Interlocks
  • Go to MDI. Type in S500 M3; Press [ENTER]. Make sure the machine is not in Setup Mode. Check the Key Switch on the side of the pendant.
  • With the door open, press [CYCLE START]. The machine should say to close the door and press [CYCLE START].
  • With the door closed, press [CYCLE START]. The Interlock Pin should extend, and the spindle starts rotating.
  • While the locks are on try to open the doors.
  • The spindle should not stop rotating but if the spindle stops, re-adjustment is required.
14
Test Auto Air Jet Blast (AJB)
Open the primary air valve. This supplies air to the machine.
Test the AJB:
  • M12: Main Spindle Air Jet Blast ON
  • M13: Main Spindle Air Jet Blast OFF
DS Machines:
  • M112: Secondary Spindle Air Jet Blast ON
  • M113: Secondary Spindle Air Jet Blast OFF
For more information regarding these M-codes refer to the Lathe Operator Manual below.
Lathe Operator's Manual
Test Auto Door Option
  • Cycle the auto door using the Auto Door button on the side of the pendant.
  • If the machine alarms out, does not close properly, or closes hard, check for the proper engagement of the Door Interlock Switch both manually and on the monitor.
  • If there is a misalignment adjust the Door Interlock Switch in or out to ensure proper engagement of the switch key.
16
Test Safety Features
  • Test Memory Lock switch by verifying that in the locked position changes cannot be made to settings or programs[1].
  • Test Run/Setup Mode switch by verifying that in the unlocked position machine functions can be done in Setup Mode[2].
  • Verify that Interlock and Actuator are installed & cable is routed correctly.
  • Verify that a window (or T/S access door) latch is installed on each side window.
  • Verify that the latch engages to keep the window or door in the up position.
  • Verify that a window or door lock is installed on each side window.
  • Verify that the window or door locks closed in the down position.
  • Verify that all lathe door locks function like the windows and doors stated above.
17
Automatic Tool Presetter (ATP) Calibration
  • If your machine includes the ATP option perform the calibration procedure
For a guide on how to perform the ATP calibration procedure please see:
ATP Calibration
18
WIPS-L Installation and Calibration
  • If your machine includes the WIPS-L option install and perform the calibration procedure
For a guide on how to install and perform the WIPS-L calibration procedure please see:
WIPS-L Installation
WIPS-L Calibration
Parts Catcher. Product of Haas CNC machine tools.
19
Test Parts Catcher (PCAT)
If your machine includes the PCAT option perform the test procedure.
  • Open CURRENT COMMANDS window on control
  • Use the arrow keys to navigate to devices and to the Part Catcher
  • Open the door
  • Use F2 to extend and retract the Parts Catcher
  • Verify PCAT extends and returns while door is open
  • Next verify PCAT extends and returns while door is closed
  • Verify enclosure PCAT door opens fully with PCAT
 NOTE: If PCAT hits the door while returning notify Haas
20
Wi-Fi Camera Installation
  • If your machine includes the Wi-Fi Camera option perform the installation procedure
For a guide on how to perform the Wi-Fi Camera installation procedure please see:
21
Mini Conveyor Installation
  • If your machine includes the Mini Conveyor option perform the installation procedure
For a guide on how to perform the Mini Conveyor installation procedure please see:
22
Updated
Test C-Axis
Test C-Axis Engagement:
  • Press [C] then [HANDLE JOG] to orient and engage the C Axis
  • Then turn handle jog wheel to rotate the C axis
Test C Axis Brake:
  • To engage spindle brake you enter M14 in MDI then press [CYCLE START] with the door closed.
  • Open the door and check that the chuck is locked into position
  • To disengage the brake you enter M15 in MDI. Close the door and then press [CYCLE START]
Lathe Maintenance Schedule
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. Please see the link below for recommended maintenance intervals.
