      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
Lathe 24V Magnetic Work Light - Installation - AD0603
Service Home How To Procedures Lathe 24V Magnetic Work Light - Installation - AD0603
Recently Updated Last updated: 03/04/2022
AD0603
Under Construction
- Jump to Section - 1. Introduction 2. Worklight Installation (1 step) Back to Top
This procedure will show you how to install the 24V Magnetic Work Light on a ST machine.
Connect the worklight power cable to the worklight extension connector that is located behind the autodoor track cover.
Position the worklight to the desired location.
Neatly arrange the cable using the magnetic cable clamp provided.
Turn on the machine and verify operation by turning on/off the worklights.
