Enclosure Exhaust - Installation - AD0184
Service Home How To Procedures Enclosure Exhaust - Installation - AD0184
Recently Updated Last updated: 12/01/2022
AD0184
Applies to machines built from: September, 1999
- Jump to Section - 1. Introduction 2. Electrical Schematic 3. Installation (10 steps) Back to Top
Some machines do not have the necessary cutout. For these machines, use this template.
On the top of the machine enclosure, measure the dimensions [A] from the front of the machine and [B] from the right side of the machine. Mark the center [C]:
  • A - 9.5" (24.1 cm).
  • B - 8.5" (21.6 cm).
 Note: For larger machines, be sure to put the cutout nearer to the work area.
Measure the dimensions [D], [E], and [F]:
  • D - Ø6.50" (16.5 cm).
  • E - Ø9.843" (25.0 cm).
  • F - 4X Ø0.375" (9.5 mm).
Cut the (1) large hole [D] and the (4) small holes [F].
 Note: For an HMC, make the cutout above the machine enclosure, behind the operator's door.
Remove the cover plate [1] from the top of the machine enclosure. If the machine does not have 4 mounting holes drilled, refer to the provided template and drill the remaining holes
ST-10/15 and ST-20/25 - Reboot Version
Install the enclosure exhaust unit sideways if the wire channel interferes with the mounting.
ST-40 and larger
Lathe models ST-40 and larger [3] have two layers of sheet metal on the ceiling of the machine. Remove the bottom cover [5] in the machine. Remove the cover [6] on the top of the machine.
Put the ENCLOSURE EXHAUST [A] on the top of the machine enclosure.
Install the (4) WASHER [D] and the (4) NUT [E] to the standoffs for the ENCLOSURE EXHAUST [A]. For lathe models ST-40 and larger [3], install the (4) WASHERS [D] and the (4) NUTS [E] between the two layers of sheet metal.
DT/DM with Auto Window Option
Rotate enclosure exhaust unit [1] by 90 degrees, so the filter access is facing the CALM cabinet. This is needed to integrate the Auto Window to the machine.
Note: Make sure that the enclosure exhaust's filter access isn't blocked by Auto Window cylinder [2].
From inside the machine, install the washer [3] and nut [4] to the standoff for the enclosure exhaust [1].
The following only applies to the UMC series
With the enclosure exhaust on a bench install the bracket using the nuts [1] and washers [2] provided.
Make sure the exhaust sits in the opening and there is no obstruction of fluid flow.
Install the exhaust and bracket assembly onto the machine, use the self tapping screws [1] to attach the bracket [2] to the machine. These screws are provided in the kit.
NOTE: It is recommend to create a pilot hole apprx  1/8" before using the self tapping screws.
Install the cable [1] from the ENCLOSURE EXHAUST [A] to the control cabinet.
Install the (4) CABLE TIE CLAMP [F] to the top of the enclosure.
Use (4) CABLE TIES [G] to attach the cable [1] to the CABLE TIE CLAMP [F].
For machines that have the Next Generation Control:
Disconnect the spindle fan cable [1] from P32 on the I/O PCB.
Connect the 3-pin connector [2] of the cable [3] from the ENCLOSURE EXHAUST [A] to P32 on the I/O PCB.
Connect the spindle fan cable [1] to the 3-pin female connector [4] of the cable [3].
Find the 2-pin connector [5] that has the label ENCLOSURE VAC SWITCH on the cable [3]. Connect that connector [5] to the 2-pin connector [6] from P34 on the I/O PCB.
For a VMC or a lathe that has the Classic Haas Control:
Disconnect the 300A cable [1] from P41 on the I/O PCB.
Connect the 3-pin connector [2] of the cable [3] from the ENCLOSURE EXHAUST [A] to P41 on the I/O PCB.
Connect the 300A cable [1] to the 3-pin connector [4].
Connect the 8-pin connector [5] to P23 on the I/O PCB.
For an EC-400/500 that has the Classic Haas Control:
Disconnect the 300A [1] cable from P41 on the I/O PCB.
Connect the 300A cable [1] to the 3-pin connector [4] of the cable [3].
Disconnect the cable labeled VAC SW [C] (not shown) from the cable [3].
Connect the 2-pin connector [5] of the cable [3] to the 2-pin connector [6] from P23 on the I/O PCB.
The ENCLOSURE EXHAUST [A] operates with the spindle.
It starts when the spindle fan starts. It stops a short time after the spindle fan stops.
Do not discard the filters [1] in the ENCLOSURE EXHAUST [A] when they are dirty. Remove the filters [1] and clean them. Use a solution of soap and water.
The ENCLOSURE EXHAUST [A] has a 10" diameter duct connection. This lets you add optional ducting [2] to the shop duct system. The kit does not include ducting.
