Lathe Maintenance Schedule - RD0035
Service Home Lathe Maintenance Schedule - RD0035
20.1 lathe - maintenance schedule
Recently Updated Last updated: 10/16/2025
RD0035
Revision A - 04/2026
Lathe - Maintenance Schedule
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. This page shows the recommended maintenance intervals.
DOWNLOAD LATHE MAINTENANCE CHECKLIST
Maintenance Item Interval
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Axis Lubrication
Inspect oil reservoir level and refill.
Monthly
Six Months
Perform an Axis Lubrication Test. Six Months
Ballscrews/Linear guides equipped with zerk fitting Monthly or weekly if cutting absorbent materials
Clean vector drive air vents / filter.
Monthly
Inspect window for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Gearbox
Inspect the oil level.
Monthly
Replace the oil.
Annually
Inspect the oil skimmer pickup tube.
Six Months
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Probe System
Check probe calibration.
Six Months
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Verify coolant refill is operating correctly.
Six Months
Inspect turret coolant lines for chips. Monthly
High Pressure Coolant (HPC) 300/1K PSI
Clean the HPC-300 / 1K Pump Filter
Six Months
Six Months
Verify the Auto Clean system is operating correctly.
Six Months
Spindle Lubrication
Inspect lubrication tank level.
Monthly
Perform Spindle Lubrication Test.
Six Months
Clean chips from the coolant collector.
Weekly
Monthly
Change the Hydraulic fluid Every 2 years or as needed per conditions
Replace the oil filter - Parker Hydraulic Unit.
Annually
Replace the oil filter - Rexroth Hydraulic Unit.
Annually
Replace the oil filter - Haas Hydraulic Unit - SL.
Annually
Grease the tailstock.
Monthly
Inspect the reservoir grease level. Monthly
Parts Catcher
Clean and lubricate the rails. Monthly
Chucks
Grease the chuck jaws.
Weekly
Chuck Multi-Point Inspection.
Six Months
Clean the Chuck Annually
Barfeeders
Grease the bar feed push rod and bushing.
Weekly
Grease the ballscrew, V-roller tracks, and rotation. (Bar 300)
Monthly
Check belt tenstion. (Haas Barfeeder)
Annually
Check push rod alignment. Six Months
