  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Remote Jog Handle (RJH-C) - Installation - AD0049
Service How To Procedures Remote Jog Handle (RJH-C) - Installation - AD0049
Recently Updated Last updated: 02/01/2021
AD0049
Applies to machines built from: February, 2009
This service kit can be used for new RJH-C installations on compatible machines, or to replace the RJH-E with an RJH-C.
Machine Compatibility
Do this procedure for these machines:
  • Software 9.02A (lathe) or 16.02A (mill) or higher.
  • 15” Monitor
  • 34-4241C – SKBIF PCB with Handle Jog
  • 34-4412A - 16MB Coldfire II PCB
KIT PN: 93-RJH-C, OPTION, REMOTE JOG HANDLE COLOR LCD
KIT PN: 30-1069B, RJH COLOR LCD, HAND UNIT
KIT PN: 93-1963, RETROFIT, RJH-E CONVERSION TO RJH-C
RJH-E Removal
If replacing an RJH-E with an RJH-C:
1. Verify that the machine meets the minimum requirements. Update hardware or software as necessary.
2. Power off the machine.
3a. (Thick Pendant) Remove the back cover of the pendant.
3b. (Storage Cabinet) Remove the back cover of the pendant, the cable cover inside the storage cabinet, and the swivel cover on top of the storage cabinet.
4. Remove the two 8-32 nuts to release the RJH-E cradle from the side of the pendant or storage cabinet.
5. Disconnect the two RJH-E cables from the SKBIF and pull them out of the control pendant, along with the cradle.
Leave the pendant disassembled for RJH-C installation.
RJH-C Wiring Installation
Free Hanging Thin Pendant or Thick Pendant with RJH-C Mounting
1. Remove the back cover of the pendant.
2. Remove any plugs or screws at the RJH-C mounting location.
3. Wire the 6’ RJ12 cord through the 1/2” hole in the pendant and connect to the SKBIF.
4. Install the end of the 6’ RJ12 cable in the RJH-C Holster.
5. Attach the RJH-C Holster to the pendant, storage cabinet or adapter bracket using three BHCS 10-32 x 1/2 screws.
RJH-C Hand Unit Installation
The holster [1] for the RJH-C is on the left side of the storage cabinet [2] (as shown).
If the machine has no storage cabinet, the holster is on the right side of the pendant [3].
Connect one end of the RJ12 COIL CORD [D] to the receptacle on the bottom of the holster.
Connect the other end to the receptacle to the bottom of the RJH-C [A].
Note: Installation of the magnifier is optional.
Remove the (2) top screws [1] on the back of the RJH.
Attach the RJH-C MAGNIFIER [B].
Use the supplied longer Phillips head SCREWS [C].
Caution: Do not remove the other screws.
Hang up the RJH-C.
Reassemble the control pendant.
Plug any unused holes.
RJH-C Testing
1. Power on the machine.
2. Lift the RJH-C from the holster and verify that the screen turns on. Hang up the RJH-C and verify that the
screen turns off.
3. Lift the RJH-C from the holster and press [EDIT] on the control pendant. In Edit Mode, the RJH-C screen reads “RJH Inactive”. Press each button on the RJH-C unit and verify that each press produces a beep from the unit.
4. Press [HAND JOG] on the control pendant. Press the far right function button on the RJH-C to cycle through the menus, verifying that the “Set Work Offsets”, “Manual Jogging”, and “Set Tool Offsets” menus display properly.
5. In Manual Jog Mode, check the axis selector, shuttle jog knob, and pulse jog knob. Jog each axis using each knob and verify that axis motion occurs as commanded.
6. Turn the axis selector to the far right position.  Command the flashlight on and off, making sure it operates as commanded.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
