High-Flow Coolant Pump (HF-MM)
Product Image
GET QUOTE
    CNY ONLY
Higher coolant pressure for MM Series
  • Option Info
OVERVIEW
VIDEOS
AVAILABLE ON THESE MACHINES
This high-flow coolant pump upgrades the standard 1/4 hp (186 W) pump to a 1 hp (0.75 kW) pump that pushes 12 gpm @ 30 psi (45 L/min @ 2 bar) @ 60 Hz, providing greatly increased coolant pressure to the cutting tool. Activated via M-code or the keypad, the high-flow coolant pump will clear chips out of the way of the cutting tool in jobs that produce a lot of chips. You’ll see nicer part finishes, and extended tool life that will save time and money.
  • Allows higher cutting speeds for cycle time reduction, and prevents re-cutting chips
  • Increases tool life by clearing chips during deep-hole drilling and blind-pocket milling
  • Improves surface quality
  • Activated by M-code, or directly from the control pendant
  • Includes coolant level sensor
VIDEOS
Coolant Pump Simple Maintenance
Orville gives some quick tips on keeping your coolant pump running at full efficiency.
Coolant Pump Troubleshooting
In this video, Service Engineer Andrew shows you how to troubleshoot your Haas flood coolant pump. Whether you feel your pump is excessively noisy, or doesn't have the flow it should, before assuming it needs to be replaced or serviced, watch this video and let Andrew walk you through the steps to troubleshoot your pump.
If Your Flood Coolant Pump Isn't Working...
If the Flood Coolant Pump on your Haas machine isn't pumping coolant, take a look at this video. Here we look at everything from the basics; like not having it plugged in correctly, to things like electrical issues and correct electrical phasing.
Need More Information?
