High-Pressure Flood Coolant (HIGH PRESSURE COOL)
Product Image
GET QUOTE
    CNY ONLY
  • Fixed displacement gear pump provides up to 14 gpm (53 L/min) of flow
  • Provides up to 60 psi (4 bar) of coolant pressure at the spindle
  • Clears chips from deep pockets to prevent recutting
  • Higher coolant flow for deep-hole boring
  • Reduces material work hardening and increases tool life
  • Produces better surface finishes by clearing chips
The number one cause of premature tool failure is re-cutting chips. Our High-Pressure Flood Pump delivers up to 45% more coolant to the cutting zone – at higher pressure – to flush out chips and swarf. High-volume, high-pressure coolant is delivered through our multi-nozzle flood coolant ring to maximize efficiency.
ATTENTION: This system is louder than the standard flood coolant system, due to the higher pressures involved, and the spur gear drive system. It is operating as expected.
NOTE: Not compatible with the Auxiliary Coolant Filter (ACF) option.
  • Option Info
DOCUMENTS
AVAILABLE ON THESE MACHINES
Service Documents
Need More Information?
