Coolant Mist Condenser (MIST CONDENSER)
Product Image
GET QUOTE
    CNY ONLY
  • Complete closed-loop recirculation system; does not require venting to the outside
  • Powered directly from the CNC control
  • Activated by M-code within the program
  • Dual mechanical filters condense the mist and return the coolant to the enclosure
Start loading parts sooner, without waiting for the coolant mist to clear from the machine enclosure. The Haas Coolant Mist Condenser keeps the machine’s enclosure clear of mist generated during the machining process – reducing health risks, reducing coolant consumption, and yielding a cleaner machine and shop.
NOTE: This is not an air filtration system. It is a mechanical system that removes coolant mist from the enclosure, condenses it into liquid coolant, and returns it to the machine. If air filtration is required, aftermarket sytems are available. Please contact a 3rd-party specialist to address your specific needs.
  • Option Info
  • Details
DOCUMENTS
VIDEOS
CUSTOMER TESTIMONIALS
AVAILABLE ON THESE MACHINES
Service Documents
VIDEOS
The Haas Coolant Mist Condenser is a complete closed-loop recirculation system that extracts coolant mist from the machine’s enclosure, runs it through dual mesh filters to condense the coolant, and then returns the condensed coolant and clear air to the enclosure.
Actron Engineering
Mist Condenser Overview
The Haas Coolant Mist Condenser is a closed-loop recirculation system that removes coolant mist from the machine’s enclosure, without venting it to the outside.
The unit works by drawing mist-filled air from the machine enclosure, and passing it over a sheet metal panel with a lipped edge. As the air passes over and around the panel, the coolant mist condenses into droplets. As more mist condenses, the droplets become heavy enough to drip off the panel’s lip and back into the enclosure.
After passing over the sheet metal panel, the air travels through a box with dual mechanical filters to condense any remaining coolant. The mist-free air is then returned to the machine enclosure through heavy-duty ducting.
The system has proven very effective at quickly clearing the air inside the machine enclosure of coolant mist, so the operator can open the door immediately after machining is complete.
This system is not MERV, EPA, or HEPA rated. If air filtration is required, aftermarket sytems are available. Please contact a 3rd-party specialist to address your specific needs.
Operation
The Coolant Mist Condenser operates manually or with M-codes.
Program M158 to turn the Mist Condenser ON
Program M159 to turn the Mist Condenser OFF
If program operation ends with M00, M01, M02, or M30 without commanding the Mist Condenser off (M159), the Mist Condenser will run for approximately 10 seconds, and then shut off.
If the Mist Condenser is running and the [RESET] button is pressed, the Mist Condenser will run for approximately 10 seconds, and then shut off. The Mist Condenser will shut off immediately if [EMERGENCY STOP] is pressed while it is running.
Manually turn the Mist Condenser on or off by pressing the [CURRENT COMMANDS] button and navigating to DEVICES > MECHANISMS > MIST CONDENSER. Press [F2] to turn on the Mist Condenser. Press [F2] again to turn it off.
Need More Information?
