Bar Feeder for the CL-1 (BARFEEDER CL)
Product Image
GET QUOTE
CL-1 Bar Feeder
    CNY ONLY
Run your CL-1 unattended
  • Overview
  • Send Info
Boost throughput and automate small-parts production on your CL-1 Chucker Lathe with this fully integrated pneumatic bar feeder. The CL-1 Bar Feeder automatically loads 0.25" to 1" (6.4 – 25.4 mm) diameter bars up to 40" (1 meter) long for extended production runs and unattended operation. Spindle speed is limited to 3000 rpm when using the bar feeder.
CAUTION: Running small-diameter material in any bar feeder can be a difficult application, and may require adjusting cutting parameters and workholding to obtain the required part quality. Small-diameter, flexible bars may “whip,” even at slower turning speeds, which can reduce accuracy and affect surface finish.
  • Easy-to-use interface in the Haas control
  • Simple bar loading procedure
  • Compact, efficient automation accessory
Need More Information?
