EU-YT Advanced Package (VF-YT-EU ADVANCED)
Product Image
GET QUOTE
EU Model Advanced Package
    CNY ONLY
Boosts the capabilities of our specially priced VF-1YT-EU or VF-2YT-EU models
  • Overview
  • Send Info
HIGH-PRODUCTIVITY UPGRADE FOR THE VF-1YT-EU AND VF-2YT-EU
VF-1YT-EU ADVANCED PACKAGE INCLUDES:
✓ Through-Spindle Coolant Ready
✓ Wireless Intuitive Probing System
✓ Coolant Maintenance Package
✓ Chip Auger
VF-2YT-EU ADVANCED PACKAGE INCLUDES:
✓ Chip Auger
Allows easy field installation of a Haas TSC system
Our Through-Spindle Coolant Ready option preconfigures your machine to accept an optional Haas Through-Spindle Coolant system. The TSC drawbar, plumbing, and wiring are preinstalled at the factory, making field installation of TSC faster, easier, and less invasive.
  • Allows easy field installation of a Haas TSC system
  • Includes the TSC drawbar, plumbing, and necessary wiring
  • Supports both Haas TSC systems: 300 psi and 1000 psi
  • Contact your local HFO for field installation
Learn more
The Advantages Of Through-Spindle Coolant
In this video, Scott and Matt demonstrate some of the advantages of the Haas TSC system by comparing traditional flood coolant and through-spindle coolant on the same drilling application.
How It Works - Through Spindle Coolan
In this installment of Haas How It Works, Mechanical Engineer Katherine White describes how the Haas TSC system works, the benefits of using TSC, and the proper applications for both 300 psi (20.7 bar) and 1000 psi (68.9 bar) systems.
Drastically reduce setup times with this complete probing package
Set up your Haas mill up to 5 times faster using the Haas Wireless Intuitive Probing System (WIPS). WIPS is a complete probing package that includes the spindle probe, tool setting probe, and optical machine interface, along with powerful software that guides the operator through the job setup process with intuitive, easy-to-use templates. WIPS allows you to quickly and easily define work offset coordinates, set tool length offsets, and perform in-process inspection, for both part inspection and tool breakage detection. WIPS is the single best productivity improvement you can add to your Haas mill.
  • Includes the Haas Visual Programming System, Macros, Spindle Orientation, and Coordinate Rotation & Scaling
  • Easy-to-use, built-in templates make programming probe functions simple
  • Fully automatic tool setting cycles
  • Includes Renishaw’s Inspection Plus software for programming advanced features, like in-process inspection
  • Includes our 50-Taper Tool Load Stand when ordered on 50-taper VMCs
Learn more
ireless Probing How-To PART 1 - Calibrating the System
Haas' Wireless Intuitive Probing System (WIPS) is a game changer for shops wanting to increase the accuracy and speed with which they set tool and work offsets. Resident Applications expert John Nelson breaks down how WIPS works in this 1st part of our "WIPS How-To" series.
Troubleshoot Your Haas Probe
Mark further troubleshoots the wireless probing system for Haas mills (WIPS). Today, Mark discusses the importance of properly indicating-in your spindle probe, deciphers the infamous “Probe Fail” alarm, and offers some useful tips on how to properly place your table probe and workholding to avoid interference. If you have a probe system, or have ever considered adding one, you need to watch this video!
Keep your coolant clean and properly mixed.
Our Coolant Maintenance Package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machine process.
  • Automatic Coolant Refill System – monitors the machine coolant level, and automatically adds correctly mixed coolant to the tank
  • Coolant Tank Oil Skimmer – automatically removes tramp oils from the surface of the coolant, extending coolant life and reducing coolant maintenance
  • Coolant Mist Condenser – keeps the machine’s interior clear of mist and smoke generated by machining, improving visibility and allowing faster workpiece exchange
Learn more
The Automatic Coolant Refill System
The Haas Automatic Coolant Refill System is designed to enhance the productivity of your shop by simplifying the way you make coolant. This option takes all the calculation, chemistry, and mixing out of the process. In this video, Andrew and Don go over some of the option’s key points, and explain why it’s an essential upgrade for your shop – saving you time and making you money.
The Haas Enclosure Exhaust System
Given the importance of cycle-time reduction these days, having to wait around for coolant mist to dissipate from a machine’s enclosure before changing parts is an expensive waste of time. That’s why Haas engineers designed an Enclosure Exhaust System that is easy to use, simple to maintain, and best of all, costs about half as much as what the competition offers.
Chip Auger
Chip Auger
Automatically remove chips from the machine
This auger-style chip conveyor automatically removes chips from the machine, while compressing them and wringing out the coolant. It is ideal for both short runs and high-production environments, eliminating the downtime required for manual chip removal. The auger can be activated via M-code or directly from the control pendant, and there are settings to control the interval and duration of the auger cycle for automatic operation. Smart-sensing technology automatically reverses the auger if a jam occurs.
  • Compresses chips, saving space in the chip bin
  • Lift angle minimizes coolant carryout
  • Automatically reverses if a jam occurs
  • Activated via M-code, or from the control pendant
  • Energy efficient via control settings for automatic operation
Learn more
AUGER - OPTION SPOTLIGHT
Here's a quick look at Haas' Chip Auger option available on all Haas VMCs. If you want spend more time making chips and less time shoveling them out of your machine, check this out.
Need More Information?
MORE TRAVEL | MORE CHOICES | MORE VALUE
EU SERIES – EXTENDED Y-AXIS
Machines configured, built, and priced just for Europe. You can’t get more personalized than that.
EXPLORE OTHER PACKAGES
