5 - BF - Maintenance
Haas Bar Feeder - Service Manual
  • 1 - BF - Introduction
  • 2 - BF - Installation
  • 3 - BF - Operation
  • 4 - BF - Push Rod and Drive Belt
  • 5 - BF - Maintenance
  • 6 - BF - Troubleshooting
  • 5.1 Haas Bar Feeder - Maintenance
5.1 HAAS BAR FEEDER - Maintenance
Haas Bar Feeder Maintenance Schedule
The Haas Bar Feeder requires little regular maintenance for optimal operation. This page shows the recommended maintenance intervals.
 Warning: Press [POWER OFF] on the lathe before you do maintenance tasks.
Maintenance Item Interval
Clean the transfer tray. As needed.
Apply grease to the push rod and bushing. Manually move the push rod back and forth to spread the grease and check for binding.
Monthly or when the push rod it dry.
Align the grease fitting in the linear guide truck with the hole in the enclosure and apply (2) strokes from a grease gun. See section below.
Monthly
Check for wear or debris in the spindle liner and replace it if necessary.
Every 6 Months
Bar Feeder - Align Grease Fitting
  • Approximately once per month, align the grease fitting in the linear guide truck with the hole [1] in the enclosure and apply two strokes from a grease gun.
