  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
4 - BF - Push Rod and Drive Belt
Haas Bar Feeder - Service Manual
  • 1 - BF - Introduction
  • 2 - BF - Installation
  • 3 - BF - Operation
  • 4 - BF - Push Rod and Drive Belt
  • 5 - BF - Maintenance
  • 6 - BF - Troubleshooting
  • 4.1 Push Rod Alignment
  • 4.2 Drive Belt Replacement
  • 4.3 Motor Pulley Installation
  • 4.4 Idler Pulley Installation
Haas Bar Feeder - Push Rod - Alignment
Jog the V-Axis from the lathe [1] until it stops.
For CHC machines operate this code in MDI mode:
G105 Q6;
This lets you remove the push rod.
For NGC machines:
Press [RECOVER] to enter the Bar Feeder Recovery page. Press [F1] to unload the push rod.
Push [EMERGENCY STOP].
Use your hand to push down the holder [2] for the push rod.
Make sure the arm moves smoothly.
Make sure the distance [4] from the face of the pusher [3] to the face of the holder [2] is approximately 0.030" (1 mm). If the distance [4] is incorrect, If the distance [4] is incorrect, refer to AXIS GRID OFFSET - NGC.
Install the push rod.
Operate this code in MDI mode:
G105 Q7;
This moves the push rod to the transfer table.
For NGC machines:
Press [RECOVER] to enter the Bar Feeder Recovery page. Press [F2] to load the push rod.
Loosen the two (2) screws [7] on the holder for the push rod and the two (2) screws [2] on the bushing holder [3] for the push rod.
Use your hand to push the pusher mechanism [1] toward the lathe until it is 2 inches from the bushing holder [3].
Tighten the screws for the bushing holder.
Push the pusher [1] until the dowel pins [5] connect to the push rod [6].
Make sure that the back plate [4] and the pusher mechanism do not touch.
Tighten the screws on the holder for the push rod.
 Note: The height of the bar feeder is possibly incorrect after the adjustment of the push rod. Refer to Haas Bar Feeder - Installation.
Haas Bar Feeder - Drive Belt - Replacement
AD0325
Applies to machines built from: April, 2015
  1. drive belt
  2. belt tensioner
  3. tension adjuster nut
  4. clamp plates
  5. drive pulley
This document applies to these parts:
  • [A] 54-0147 QTY: 1 BELT, BARFEEDER AT5 153 INCH
Tools Required:
  • Gates 505C or 507C Sonic Tension Meter (T-0039)
Push [POWER OFF] on the lathe.
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker.
Remove the front enclosure panel.
To remove the belt [A]:
  • Loosen the (2) screws [1] on the tensioner [2]. This lets the tension adjuster [3] move.
  • Loosen the tension adjustment nut [4] to remove the belt [A] tension.
  • Loosen the (4) screws [5] on the right clamp plate [6]. Remove the belt [A] from the right clamp plate [6].
  • Loosen the (4) screws [7] on the left clamp plate [8]. Remove the belt [A]from the left clamp plate [8].
Put the new belt [A] through the left clamp plate [8]. Torque the (4) 10-32 socket head cap screws (SHCS) [7] to 25 in-lb (282 N-cm).
Put the new belt [A] around the idler pulley [9].
Use your hand to pull the belt [A] until it is tight. Put the belt through the right clamp plate [2]. Torque the (4) 10-32 SHCS [1] to 40 in-lb (452 N-cm). Tighten the tension adjustment nut [3] until the belt [A] has tension.
To prepare the Gates Sonic tension meter:
  • Connect the sensor cable to the meter.
  • Push [POWER] [4].
  • Push [MASS] [5] (507C model) or [WEIGHT] (505C model). Enter the correct belt values for "Mass/Weight". Enter the correct belt values for [WIDTH] [6] and [SPAN] [7].
Mass/Weight 3.3 g/m
Width  25 mm
Span 1700 mm
  • Push [Hz] until the display shows T ---------lbf[9].
  • Push [MEASURE] [10].
Use your hand to move the tensioner [1] fully to the left.
Put the sensor [2] less than 3/8" (9.5 mm) from the middle section of the belt [A].
Quickly pull your finger across the edge of the belt ("pluck" the belt like a guitar string). Do not let the sensor touch the belt. If you cannot make the necessary vibration with your finger, you can tap the belt with the handle of a screwdriver. Make sure the tension value shown on the meter is 75 lbf +/- 5. Adjust the tension adjustment nut [3] as necessary.
Measure the tension again. Adjust the nut [3] until the belt tension is correct. Torque the (2) 1/4-20 SHCS [4] to 12 ft-lb (16 N-m).
Install the front enclosure panel.
For a CHC Machine refer to Haas Bar Feeder Operator's Manual for more information about setting up the Bar Feeder.
For a NGC Machine see the link below for the setup procedure.
Haas Bar Feeder - Lathe Setup - NGC
Haas Bar Feeder - Motor Pulley - Installation
AD0592
This document and service kit applies to Haas Bar Feeders built 02/09/2015 and later:
  • 93-20-6494A - SPKT AT5-38AT5/30-2 19MM BORE BARFEED
Pulley Removal
Loosen the belt to remove the motor[A]:
Loosen the (4) screws [5] on the right clamp plate [6] to loosen the belt [A] from the right clamp plate [6].
With the belt loose, remove the motor from the bar feeder.
To remove the sweat fit pulley use a torch and evenly heat the outer diameter of the pulley.
As the pulley is heated up, pull on the pulley until it slips free.
Tips & Tricks: Place the motor with the motor shaft facing down and the pulley free to fall down from the shaft once heated.
Note: Do not pry or cause damage to the motor shaft when removing.
Pulley Installation
Install the key to the motor shaft.
Install the pulley onto the motor shaft until it stops.
Install the set screws and torque to 7 ft-lbs.
Follow the Haas Bar Feeder - Drive Belt - Replacement procedure to tighten the belt.
  • 93-3514 - DRIVE BELT IDLER KIT HAAS BAR FEEDER
Idler Pulley Assembly
Assemble the idler pulley.
Install the Idler Pulley assembly to the center hole on the main chassis plate and torque to 10 Ft-lbs.
Verify that the belt tension is set to the correct tension. See the Haas Bar Feeder - Drive Belt - Replacement procedure for checking and adjusting the belt tension.
Check that the belt does not skip on the motor pulley after installing the idler pulley and setting the belt tension.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
