2 - BF - Installation
Haas Bar Feeder - Service Manual
  • 1 - BF - Introduction
  • 2 - BF - Installation
  • 3 - BF - Operation
  • 4 - BF - Push Rod and Drive Belt
  • 5 - BF - Maintenance
  • 6 - BF - Troubleshooting
  • 2.1 Haas Bar Feeder NGC - Installation
  • 2.2 Haas Bar Feeder CHC - Installation
  • 2.3 Haas Bar Feeder CHC to NGC Conversion
  • 2.4 Haas Bar Feeder - Chamfer Device installation
  • 2.5 Extended Liner System - Installation
2.1 HAAS BAR FEEDER - NGC Installation
Haas Bar Feeder - Installation - NGC
AD0406
Revision C - 06/2026
The Haas Bar Feeder is for ST10/15/20/25/30/35 and DS-30 lathes.
It is not for ST-30/35 or DS-30 lathes with a gearbox.
This procedure tells you how to install a bar feeder that was made after June, 2017. If you have CHC machine please follow the procedure below.
Haas Bar Feeder - Installation - CHC
Machine Compatibility:
Product Software Version I/O PCB Axis Motor Type Factory Setting 13.116 BF-Axis Encoder Type
Haas Bar Feeder 100.17.000.2030 or higher 34-308xC
34-3490x with TC PCB (93-32-5502)
Sigma - 5 7
Haas Bar Feeder V2 100.17.000.2030 or higher 34-308xC
Sigma - 7
Note: This motor has a blue line on the back of the encoder housing.
  • Download the latest configuration files to make sure Factory Setting 13.116 BF-AXIS ENCODER TYPE appears on the the factory setting tab.
  • Update the I/O Main and TC firmware version to the latest. Refer to Next Generation Control - I/O PCB Main Firmware - Update for the latest firmware for the machines I/O  & TC PCB part number.
  • Haas Bar Feeder installation kit
  • ST-10/15/20/25/30/35 NGC lathes built after Jan 14, 2019 are equipped with I/O PCB (34-3490B).  This I/O PCB does not have the circuitry to power the Bar feeder DC motor. Bar feeders built after Jan 14, 2019 will have a tool changer PCB kit included in the bar feeder electrical installation kit.   If you receive a bar feeder that does not have the tool changer PCB kit you need to order P/N: (93-32-5502)
  • Liner guide adapter kit
  • USB Service Key
  • ST-10/10L/10Y/10LY machines built after April 4, 2022 can order an Extended Liner System Kit to allow the Bar Feeder to take longer stock.
 Note: Do not discard the anchor kit.
Press [POWER OFF] on the lathe.
Set the main circuit breaker to the OFF position.
If the lathe is an ST-35, or if the machine was made before 11/1/2015, install the coolant collector extension [1] onto the lathe.
Attach the spindle liner adapter [2] to the spindle. Refer to Lathe - Extruded Spindle Liner - Adaptor Kit - Installation. If the lathe is an ST-35, refer to Lathe - ST-30/30Y Big Bore, ST-35/35Y - Spindle Liner Kit - Installation.
Put the bar feeder adjacent to the lathe.
Make sure the frame ends [1] are parallel to the front [2] of the lathe.
Remove the shipping brackets [3] from the frame of the bar feeder.
Updated
Remove shipping bolts [1] from both sides of the bar feeder.
Pull the bar feeder [1] forward until it locks into position.
Find the end of the bar feeder [2].
If the lathe is an ST-35, find the end of the coolant-collector extension [3].
If the lathe is an ST-10, ST-15, ST-20, ST-25, ST-30, or DS-30, find the edge of the coolant collector.
Make sure that the space [4] between them is approximately 0.50" (13 mm).
Warning: If this distance is set incorrectly the first push of a new bar goes past the initial push length location or when pressing Advance Bar [F3], this pushes the bar past the end of the spindle face. Adjust Parameter 602 by the difference of this distance. Length unit is mm.
Find the (4) height adjustment screws [1].
Turn the screws [3] until the frame is 2.0" (51 mm) [2] above the floor [4].
Haas Bar Feeder - Electrical Installation
Updated
Find the access door [2] at the bottom of the control cabinet [1].
Open the access door.
Note: Not all machine models include an access door at the bottom of the control cabinet. Access points may vary by configuration.
Install the conduit bracket [3] to the bottom of the control cabinet.
Use (2) screws to attach the bracket.
Find the cable conduit [2] under the bar feeder.
Put the cable conduit through the hole [1] in the side of the lathe enclosure.
 Note: Some lathes do not have the hole. If the lathe does not have a hole, make one with a 2.0" (51 mm) hole saw. No hole is necessary for the ST-10.
Put the conduit through the conduit bracket [3].
Push the conduit [5] up through the cable exit [4] in the bottom of the control cabinet.
 Note: For machines with the Bar Feeder Chamfer purchased option, leave its power cord unplugged. The chamfer device installation will be later in this procedure.
Open the control cabinet.
 Danger: If the voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED to go off fully.
Find the location on the amplifier bank that has the "BAR FEEDER /W AXIS" label [1].
Install the 30-Amp servo amplifier [2], included with the bar feeder, into that location.
Find the (3) bar feeder power wires that come through the conduit.
Connect the power wires to the high voltage terminals:
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
Connect the ground wire [4] to the bracket for the amplifier fan.
Find the high-voltage terminals [5] on the nearest amplifier.
Find the high-voltage terminals [7] on the bar feeder 30-Amp amplifier.
Install the jumpers [6] from the installation kit between these terminals.
Connect the black wire to -H.V. Connect the red wire to +H.V.
IMPORTANT: Install a ferrite filter [8] (P/N 64-1252) bead around the red, white, black cables going to the bar feeder motor.
Connect the current command cable, included with the bar feeder, to the connector [1] at the top of the amplifier.
Connect the other end of the cable:
  • Connect to channel 10 (P10) [2] on the Maincon PCB.
Find the servo motor encoder cable in the conduit.
Connect the servo encoder cable:
  • Connect to channel 10 (P26) [3] on the Maincon PCB.
IMPORTANT:  Make sure ferrite bead [4] is installed on the servo encoder cable.
Updated
For Lathes equipped with the 34-348xA, 34-348xC  I/O PCB:
Connect these cables from the conduit to the I/O PCB:
  • Cable 200 to P62 [1].
  • Cable BF Input to P59 [2]. Install a ferrite filter P/N 64-1252 bead around the cable at the I/O board.
  • Cable 810 to P58 [3].
For Lathes equipped with the 34-349x
IMPORTANT: Install a ferrite filter P/N 64-1252 bead around the cable at P59 on the I/O board.
For Lathes equipped with the 34-349x I/O PCB:
 Note:  Bar Feeders built after January 14, 2019 will have a Tool Changer PCB kit included in the electrical kit.
  • Install the TC PCB on the standoffs.
  • Connect cable P/N 33-0413 from J1 [2] on the TC PCB to P74 [3] on the I/O PCB.
  • Connect cable P/N 33-0412 from P55A [4] on the TC PCB to P55 [5] on the I/O PCB.
  • Connect cable P/N 33-0349 from P4 on PSUP PCB to the P55 [7] on the TC PCB.
  • Connect the bar feeder cable to P58 [6].
Note: If the machine generates multiple Alarm 20014.1 SIO TOOL CHANGER PCB IS NOT PRESENT and 20014.0 SIO TOOL CHANGER PCB PRESENT after the I/O TC PCB is installed. The I/O or TC PCB firmware is outdated. Update I/O Main and TC firmware version to the latest.  Refer to Next Generation Control - I/O PCB Main Firmware - Update.
Note: Cable 33-5712A (NGC-CF Adapter Cable) is only required for CHC machines. If the machine is not equipped with this control, disregard the adapter.
Enable Bar Feeder
Set the main circuit breaker to the ON position. Press [POWER ON].
Find the "Parameters" decal on the right rear panel of the bar feeder. Use a Service Key to set this parameter in the Factory parameter tab:
  • Set parameter 13.078 BF TOOL CHANGE OFFSET. (Units are in millimeters)
  • Set parameter 13.116 BF-AXIS ENCODER TYPE to the correct value.  See the compatibility table for the correct value.
Activate the bar feeder in the Settings page:
  • Change Setting 336 Bar Feeder Enabled, to ON.
Cycle Power the machine.
Zero Return the machine.
Haas Bar Feeder - Alignment
Look at the transfer table [1] on the bar feeder.
The groove in the transfer table aligns with the spindle adaptor.
Tap the frame ends [2] with a rubber mallet [3] to horizontally align the bar feeder.
Press [EMERGENCY STOP].
Turn the adjustment wheel [3] for the transfer table until the table is at the bottom.
Install the 0.75" push rod [2] on the push rod assembly [1].
Refer to the Operator's Manual for instructions to install the push rod.
Remove the left-hand rack for the spindle liners.
Remove the sticker [3] from the socket hole [4] on the bar feeder.
Put the sticker above the socket hole.
Find the (8) cart screws [5].
Each side of the bar feeder has (4) screws.
Loosen the (8) screws.
Put the adjustment tool [2] into the socket.
Release the [EMERGENCY STOP].
Press [RESET] to stop each alarm.
Press [RECOVER] to enter the bar feeder recovery mode:
Press [F2] to load the push rod.
The pusher clears the tray then the push rod assembly moves down.
Use your hand to move the push rod actuator [1] toward the lathe.
Use the adjustment tool [3] to move the bar feeder [2] up or down until the push rod can go into the liner adaptor.
Perform the Haas Bar Feeder - Push Rod Alignment procedure.
Make sure the enclosure [1] is level to the ground.
Tighten the (8) cart screws [2].
Remove the adjustment tool.
Replace the racks for the spindle liners.
Find the (4) height adjustment screws [3].
Look at where the push rod [2] goes into the spindle adapter [1].
Turn the (4) height adjustment screws until the center of the push rod aligns with the center of the adapter.
Look at where the push rod [4] goes out of the spindle [3].
Turn the (4) height adjustment screws until the center of the push rod aligns with the center of the spindle.
 Note: Gravity pulls the end of the push rod down a small distance.
Tap the frame ends with a rubber mallet to move the bar feeder from side-to-side, if necessary.
Return the push rod to its home position.
Step on the release pedal.
Push the bar feeder backward to the end of its travel.
If the bar feeder is correctly leveled, the gas shock holds the bar feeder in the rear location.
If the bar feeder must be aligned, adjust the rear feet until the bar feeder smoothly locks in the forward position and moves fully backward.
Haas Bar Feeder - Anchor Instructions
Turn the rear feet [1] until they are parallel to the bottom rails, as shown.
The front feet [2] must remain perpendicular to the bottom rails, as shown.
Use a pen [1] to put a mark on the floor at the location of each foot.
 Note: Turn the feet to the sides of the bar feeder to avoid a tripping hazard.
Drill [2] a Ø 0.50" (13 mm) hole in each mark.
Drill the hole to a depth of 3.5" (89 mm).
Put a washer and a nut on the bolt [1].
Put the foot over the hole .  Put the anchor into the hole.
Use a hammer [2] to tap the anchor.
Tap the anchor [3] until it is at the bottom of the hole.
Torque each nut [4] to 55 ft-lb (75 Nm).
Haas Bar Feeder Chamfer Device Installation
Follow the Bar Feeder Chamfer Device procedure to install the Bar Feeder Chamfer Device if equipped.
Haas Bar Feeder - Calibration Instructions
Perform this procedure one time at installation. The Run/Setup Key Switch must be in Setup Mode to calibrate the EOB Switch.
Press [RECOVERY] button to enter the bar feeder recovery mode.
Place a precision ground calibration bar with a known length on the charging table.
Press [ORIGIN], type in the length of the calibration bar and press [ENTER].
The pusher clears the tray then loads the calibration bar. It will then measure the length of the bar and apply the calibration.
Remove and properly store the calibration bar for future use. A bar feeder only needs calibration at installation, or if the EOB sensor, home switch, or trolley are disassembled or replaced.
Note: If the message No Material Found is displayed when the bar is pushed towards the spindle passed the EOB sensor during calibration. Update the I/O Main and TC firmware version to the latest. Refer to Next Generation Control - I/O PCB Main Firmware - Update for the latest firmware for the machines I/O  & TC PCB part number.
The bar feeder installation is complete. Refer to the Haas Bar Feeder - NGC Lathe Setup procedure to setup the bar feeder.
2.2 HAAS BAR FEEDER - Classic Haas Control Installation
AD0179
Applies to machines built from: April, 2015 to May, 2017
The Haas Bar Feeder is for ST10/15/20/25/30/35 and DS-30 lathes. It is not for ST-30/35 or DS-30 lathes with a gearbox. This procedure tells you how to install a bar feeder that was made after April, 2015 until May, 2017.
Prerequisites
  • Lathe software 11.22A or higher
  • Latest version of the Parameter Checker Program
 Note: Do not remove the red shipping brackets before the bar feeder installation.
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
  • If the machine has a Y Axis, connect to P2 [2] on the Mocon PCB.
  • If the machine does not have a Y Axis, connect to P3 [3] on the Maincon PCB.
Find cable 90C in the conduit.
Connect cable 90C to P13 [1] on the PSUP PCB.
Install the cover for the PSUP PCB.
Find the servo motor cable in the conduit.
Connect the servo motor cable:
  • If the machine has a Y Axis, connect to P6 [2] on the Mocon PCB
  • If the machine does not have a Y Axis, connect to P7 [3] on the Maincon PCB
  • Cable 200 long lead connector [1] to P35
  • Cable 240 to P21 [2]
  • Cable 440 to P24 [3]
  • Cable 810 to P59 [4]
Haas Barfeeder Configured for NGC
Do this section if your Haas Bar Feeder is configured for a Next Generation Control, if not skip this section.
Locate adapter P/N 33-5712A that came with the NGC Haas Bar Feeder, or that came with the 93-3500 service kit.
Connect the Bar Feeder Inputs cable P/N 32-5715 to the NGC to CHC adapter P/N 33-5712A.
Connect the End of Bar Sensor cable P/N 32-7465 to the NGC to CHC adapter P/N 32-5712A.
Connect the NGC to CHC adapter P/N 32-5712A to I/O PCB P24, P21, P35.
Connect dc motor cable P/N 33-2017 to I/O PCB P59.
Tap the frame ends [2] with a rubber mallet [3] to move the bar feeder.
The end of bar switch is calibrated at the factory. It is not necessary to run the G105 Q5 command.
Make sure to set these parameters.
  • Set parameter 734:30  BRFEED SP LK/SB EOB to 1.
  • Set parameter 390:3  V AXIS DISABLED to 0.
Press [PARAM/DGNOS]. Find the "Parameters" decal on the right rear panel of the bar feeder. Set these parameters to the values on the decal:
  • Parameter 415  TOOL CHANGE OFFSET
  • Parameter 611  BAR FEEDER TYPE
  • If you have software 11.25A or higher, do not use the value for parameter 409 from the decal.
    • Set parameter 409  V GRID OFFSET to -9000.
    • Set parameter 1119  V AXIS ZERO RETURN METHOD to 6.
  • If you have software 11.24 and lower, do not use the value for parameter 409 from the decal.
    • To set parameter 409 V GRID OFFSET do the Axis Grid Offset - Mill 13.14 or Higher and Lathe 6.11 or Higher procedure for the V-Axis.
    • Set parameter 1119  V AXIS ZERO RETURN METHOD to 0.
Make sure the values are correct for the other parameters. Use the Parameter Checker Program - Menu Option (7).
Operate this code in MDI mode:
G105 Q6
The push rod assembly [1] moves up.
Install the 0.75" push rod [2].
Refer to the operator's manual for instructions to install the push rod.
G105 Q7
The push rod assembly moves down.
Drill the hole to a depth of 2.0" (51 mm).
Put the foot [3] over the hole [4].
Put an anchor [2] into the hole.
Use a hammer [1] to tap the anchor.
Tap the anchor until it is at the bottom of the hole.
Put a washer [6] and a nut [5] on the bolt.
Torque each nut to 55 ft-lb (75 Nm).
Haas Bar Feeder Chamfer Machine Installation
Follow the Bar Feeder Chamfer Device procedure to install the Bar Feeder Chamfer Machine if equipped.
2.3 HAAS BAR FEEDER - CHC to NGC Conversion
Converting Haas Bar Feeder CHC to NGC
AD0464
This procedure will show you how to convert a Haas Bar feeder that was configured to run on a Classic Haas Control to a Next Generation Control (NGC). This kit also includes an adapter P/N 33-5712A that will allow you to connect the Haas Bar feeder back to a Classic Haas Control. The installation of this adapter will be covered in the Haas Bar Feeder - Installation - CHC procedure.
Follow the Haas Bar Feeder NGC - Installation procedure below after converting the Haas Bar Feeder.
This procedure applies to the following kit:
  • 93-3500    CF To NGC Haas Bar Feeder Kit
CHC Parts Removal
Remove the 32-7464 CBL200 END OF BAR PHOTO SENSOR N.C. photo sensor [1].
Note: If the Bar feeder is installed to a Classic Haas Control machine disconnect the cable P/N 32-7464 at I/O PCB P35 and PSUB PCB P13 .
Remove the 25-11030 BRKT BAR MEAS SW BARFEED photo sensor bracket [2].
Remove the 69-1734 N.C. LOAD “Q” proximity switch [4]
Remove the 69-1733 N.O. LOAD BAR proximity switch [5]
Remove the 69-1733 N.O. DOOR SW proximity switch [3].
Remove the 69-1733 N.O. PUSHED OUT proximity switch [6] mounted in lower part of the bar feeder.
Remove cables p/n 33-2018 and 33-2016 from the bar feeder.
Note: If the Bar feeder is installed to a Classic Haas Control machine disconnect the cables P/N 33-2016 at I/O PCB P21 and cable p/n 32-2018 at I/O PCB P24 .
NGC Parts Installation
Install the end of bar bracket p/n: 25-11030A END OF BAR SW BRKT BARFEED.
Install the end of bar photo sensor p/n: 32-7465 CBL200 END OF BAR SENS 12V.
Install the proximity switches cable p/n: 32-5715 N.O. PUSHED OUT,  N.O. DOOR SW,  N.C. LOAD “Q” and N.O. LOAD BAR to their correct location.
Insert the cables inside the conduit and follow the same cable routing as the previous configuration.
The NGC control uses  parameter 13.78 instead of 415 for the V-axis Tool Change Offset.  The NGC control uses millimeter values for parameter 13.78 V-Axis Tool Change Offset instead of encoder steps.  It is necessary to convert the Classic Haas Control Parameter 415 V-Axis Tool Change Offset value to millimeters.
On the back of the Bar Feeder locate the "Haas Bar Feeder Parameter" decal (29-0987).
Write down the number listed in the decal for parameter 415. Divide this number by 44390.  Convert the results to millimeter.
Example:  77461 / 44390 = 1.7450
1.7450 x 25.4 = 44.323 (MM)
Remove the old decal and install decal 29-0987A DECAL PARAMETERS HAAS BAR FEEDER.
Use a permanent marker to write down the value of NGC parameter 13.078.  This value will be needed during installation.
Install the Bar Feeder:
  • NGC Lathe,  Refer to Haas Bar Feeder - Installation - NGC
  • CHC Lathe, Refer to Haas Bar Feeder - Installation - CHC
Servo Motor Cable Upgrade
The Haas Bar feeder servo motor cable has been upgraded to a braided style.  Complete this section only if the Haas Bar Feeder was built before April, 2017 and it will be connected to a NGC machine.
Locate the Servo Motor.
Disconnect the encoder cable [1] from the motor. Disconnect the cable going to the home sensor [3].
Disconnect the Motor power cable [2] from the motor.
Install the updated encoder/home sensor cable p/n: 32-0484.
Install the updated motor power cable p/n: 32-1650.
Note:  The updated motor power cable p/n: 32-1650 will require a ferrite filter p/n: 64-1252 installed at the amplifier side when installing the bar feeder to an NGC Lathe..
2.4 HAAS BAR FEEDER - Chamfer Device Installation
Lathe - Bar Feeder Chamfer Device - Installation
AD0744
Revision B - 04/2026
This procedure will show how to install a Chamfer Device onto a Bar Feeder for both the service kit and the purchased option.
  • ST-10/15/20/25/28/30/35/L/Y/LY with Haas Bar Feeder
  • ST-20/30/SS/Y/SSY with Haas Bar Feeder
  • DS-30Y with Haas Bar Feeder
  • 93-1001009 BAR CHAMFER FIELD INSTAL KIT BARFEED
 Note: This procedure uses a ST-20 for illustrative purposes. The same applies to all machines listed above unless otherwise specified.
Remove Bar Feeder table cover [1].
 Note: Bar Feeders bought with chamfer option will not require this step. The table will come with holes for mounting the chamfer machine.
For kit P/N 93-1001009:
Place the template [1] on the Bar feeders second rail [2], closest to the machine.
Use the template to mark the four holes.
Remove template then drill 5/16th holes in the marked locations.
Deburr both sides of each hole.
Route power cable [1] through the bottom opening [2] of the control cabinet, under the side skirt [3], and behind the Bar Feeder's back panel [4] next to the corrugated tubing [5].
 Note: Bar Feeders bought with chamfer option will come with the power cord already routed through the corrugated tubing [5] which should be installed using the steps in the Haas Bar Feeder - Installation procedure.
Leave the cable disconnected from power.
Install the chamfer cutter [1] onto motor shaft [2] by lining up the key way [3].
Snug the bolt [4] hand tight. Verify that the chamfer cutter is securely attached to the motor shaft.
Bolt the chamfer device [1] onto the underside of the Bar Feeder table.
Updated
Plug the foot pedal cable 33-1293 [1] into the chamfer device cable 32-1296 [3] and power cable routed through the control cabinet 33-1303 [2].
 Reference name on cable to verify correct location.
Remove the Bar Feeder’s back panel [1].
Use the self-tapping screws and cable clamps [2] to secure the power [3] and foot pedal [4] cables to the support bar [5] on the underside of the table.
Updated
Attach the foot pedal cable [1] to the Bar Feeder using two of the three cable clamps [2] behind the Bar Feeder back panel.
Note: The foot pedal may be positioned at the operator’s discretion for optimal accessibility. Securing the cable with the provided clamps is optional and may be omitted if additional cable length is required to place the pedal closer to the operator.
Install the Bar Feeder's back panel [1].
Attach the power cable [2] to the corrugated tube [3] between the machine and Bar Feeder using zip ties [4].
 Note: Bar Feeders bought with chamfer option will have the power cable routed through the corrugated tube [3].
Plug power cord into control cabinet [5].
Verification
Step on the foot pedal to verify the chamfer machine turns on.
The cutting surface should rotate counter clock-wise.
Lathe - Extended Liner System - Installation
AD0640
This document and service kits applies to ST-10/10L/10Y/10LY machines built 04/01/2022 and later:
  • 93-1000844 - LINER SYS 46 X 1500 MM
  • 93-1000845 - LINER SYS 1.8 X 60"
 Note: The coolant collector is not shown in some images for illustrative purposes but does not need to be removed for this procedure
Remove the side panel [1] next to the coolant collector.
Important: If a bar feeder is currently installed on the machine it will need to removed and reinstalled after this procedure. Refer to Haas Bar Feeder - Installation - NGC for more details.
Use the bolts [1] to adjust the stand so that it sits about 2.125 in (54 mm) [2] off the floor on the bolts.
Once the feet [3] are added, the stand should be about 47 in tall (1194 mm) [4] and perpendicular to the floor.
Note: Use a bubble level to ensure the stands base and back are leveled.
Remove the angled panel [1] on the stand.
Position the stand so that it is sitting between 12.125 - 12.25 in (308 - 311 mm) [1] from the side of the machine and in line with the coolant collector's center.
The stand should be 0.200 - 0.250 in (5 - 6 mm) [2] from the coolant collector to allow room for adjustment.
Adjust the stand until the circular opening is visually concentric [3] with the piston and spindle.
Lock spindle and install the extended liner adaptor [1] through the stands opening onto the piston threads [2] hand tight.
Unlock spindle and measure the runout of the end of the extended liner adaptor and mark the high spot [1].
Note: Use the closer to rotate the extended liner adaptor.
Position the extended liner adaptors high spot [1] to point up.
Grease the inside [2] of the housing then install housing over the extended liner adaptor and hand tighten the screws [3] in a star pattern.
Note: Make sure the screws have full clearance of the through holes. If needed, reposition the stand until there is full clearance.
Align the base of the anchor [1] with the centerline of the bolts [3] then move it towards the stand until it touches the puck [2].
Mark the far end of the slot with a marker [1] then remove anchor assembly and repeat for all 4 corners.
Once all corners are marked anchor machine based off Anchoring Instructions.
Important: Leave the anchors loose to allow movement for alignment.
Anchors should be installed in this orientation before alignment.
Alignment
The following steps hone in on alignment.
Drop the chuck pressure to 180 psi [1].
Snug the bolts [1] on the housing down to make the stand perpendicular to the extended liner adaptor, tap the sides of the stand to help align it.
 Note: The back of the stand needs to be perpendicular to the Z-axis. Check for gaps between the housing and the stand, adjust until the housing is flush with the stand all the way around.
Torque housing bolts [1] to 15 ft lbs. in a star pattern.
Bottom out bolts and stop when they make full contact with the pads.
Torque the 4 anchor nuts [1] to 25 ft lbs.
Once all bolts and nuts from the previous steps have been tightened or torqued, actuate the chuck to check for binding.
 If there is binding, determine bind direction. Lightly push and pull on stand in Z axis direction to listen for the binding sound to decrease. Based on this direction, adjust both back 2 bolts [2] to 1/8 of turn increments or less.
 Note: Repeating steps 2-7 may be necessary if binding does not improve after implementing this step.
If no binding occurs, evenly snug nuts (4) [1] and give them an 1/8th of a turn.
Reinstall the angled panel [2] on the stand.
Once all the bolts are tightened down and there is no binding when actuating, change setting 282 to I.D. [1].
Press [SETTING], type in 282, and press [F1] to search for setting 282. Change the value in setting 282 to I.D.
Use spanner wrench [2] to tighten extended liner adaptor [3].
Tighten the collar set screws [4] in a star pattern. The collar should be fully pressed up against the extended liner adaptors shoulder.
Change setting 282 back to O.D.
Check the runout of the end of the extended liner adaptor, NTE 0.0030".
Install the retaining clip [1], coolant collector extender [2], and access cover [3].
Note: The coolant collector extender has a hose that needs to be fed through the stand and coolant collector.
Reinstall the side panel next to the coolant collector.
Bar Feeders should be placed between 24.125 - 24.375 in (613 - 619 mm) [1] from the side of the lathe and 0.125 in (3 mm) [2] from the access cover handle [3].
To install a Bar Feeder, follow HAAS BAR FEEDER - INSTALLATION
Before anchoring the Bar Feeder down, verify it clears the access cover handle [3].
Extended Liner System Activation
Turn on the machine.
Login to the HBC PORTAL.
Download the Extended Liner System option configuration patch files.
 Note: The option files will appear on the configuration download page after the Extended Liner System service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Decal
The extended liner system decal location [1].
The decal [2] illustrates the following specifics:
  • Bar Straightness - This aids in minimizing vibration and preventing the potential of jamming bars within the spindle.
  • Chamfering - This process serves to avert both jamming and the possibility of marring the liners.
  •  Maximum RPM - This consideration is crucial in order to effectively diminish vibration.
  • Procedure for Removing the Retaining Clip - Prevent the loss of the clip during removal. To achieve this, it is recommended to press down on the clip with a finger to counteract it from springing out.
