15 - UMC - Maintenance
UMC-Series - Service Manual
  • 1 - UMC - Introduction
  • 2 - UMC - Specifications
  • 3 - UMC-400/500/750 - Installation
  • 4 - UMC-1000/1250 - Installation
  • 5 - UMC-1500-DUO/1600-H - Installation
  • 6 - UMC - Anchoring
  • 7 - UMC - Operation
  • 8 - UMC - Geometry and Alignment
  • 9 - UMC - MRZP and Safe Zones
  • 10 - UMC - B/C - Rotary Axis
  • 11 - UMC - Tool Changer
  • 12 - UMC - Chip Removal and Coolant
  • 13 - UMC - Electrical Control
  • 14 - UMC - Lubrication
  • 15 - UMC - Maintenance
  • 16 - UMC - Pallet Pool
  • 17 - UMC - Hydraulic Workholding
  • 18 - UMC - Pneumatic Workholding
  • 15.1 UMC - Maintenance Schedule
  • 15.2 UMC - Service Replacements
UMC Maintenance Table
Automatic Tool Changer - SMTC
Maintenance Item Interval
Clean the chips from the tool changer.
Weekly
Inspect the arm plunger and adjuster assembly.
Six Months
Clean and lubricate the pocket tool plungers.
Six Months
Clean and lubricate the track on the carousel housing that the tool pocket rollers ride on (SMTC30/50 only).
Six Months
Grease the tool changer cams.
Annually
Inspect and replace worn pocket components: springs, plungers.
Annually
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Axis Lubrication
Inspect grease reservoir level.
Monthly
Six Months
Perform an Axis Lubrication Test. Six Months
Clean vector drive air vents / filter.
Monthly
Inspect windows for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Minimum Quantity Lubrication
Clean the filter inside the oil reservoir.
Annually
Inspect the oil skimmer pickup tube.
Six Months
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Probe System
Check the probe batteries.
Six Months
Check probe calibration.
Six Months
Inspect the oil level.
Annually
Replace the oil.
Two Years
Inspect the A-Axis counterbalance cylinder for oil leaks. Two Years
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Clean the standard coolant filter.
Six Months
Verify coolant refill is operating correctly.
Six Months
Through Spindle Coolant (TSC) 300/1K PSI
Clean the TSC-300 / 1K Pump Filter
Six Months
Six Months
Verify the Auto Clean system is operating correctly.
Six Months
Spindle
Clean and lubricate the spindle taper.
As Required
Spindle drawbar force measurement.
Annually
Spindle Lubrication
Inspect lubrication tank level.
Monthly
Perform Spindle Lubrication Test.
Six Months
Tooling
Grease Pull Studs.
As Required
UMC-750 - AutoCam - Replacement
This only applies to non-reboot UMC-750 machines.
Part Number Part Description
57-0875 V-RING V-375L BUNA-N (NBR)
57-0876 O-RING 5.7MM X 339.3MM BUNA SHORE A 70
57-0877 O-RING 3.1MM X 344.3MM BUNA SHORE A 70
57-0878 O-RING 3.1MM X 239.3MM BUNA SHORE A 70
57-0879 R SEAL 210MM X 225.5MM X 6.3MM
57-0880 S SEAL 155MM X 180MM X 15MM
57-0881 O-RING 3.1MM X 179.30MM BUNA SHORE A 70
57-0882 O-RING 3.1MM X 244.3MM BUNA SHORE A 70
57-0883 O-RING 5.7MM X 239.3MM BUNA SHORE A 70
93-62-10027 SERVOMTR YASKAWA SIGMA V-30 W/O BRK
