1 - Desktop Mill - Introduction
All Manuals
Desktop Mill - Operator's Manual Supplement
  • 0 - Desktop Mill - Table of Contents
  • 1 - Desktop Mill - Introduction
  • 2 - Desktop Mill - Legal Information
  • 3 - Desktop Mill - Safety
  • 4 - Desktop Mill - Installation
  • 5 - Desktop Mill - Control Icons
  • 6 - Desktop Mill - Operation
  • 7 - Desktop Mill - G-Codes
  • 8 - Desktop Mill - M-Codes
  • 9 - Desktop Mill - Settings
  • 10 - Desktop Mill - Maintenance
  • 11 - Desktop Mill - Troubleshooting
  • 1.1 Introduction
  • 1.2 Axis Definitions
  • 1.3 Specifications
  • 1.4 How To Use This Manual
  • 1.5 Desktop Mill Version - Identification
1.1 Introduction
Overview
This operator’s manual supplement describes the unique features and functions of the Desktop Mill. Refer to your Mill Operator’s Manual for control operation, programming, and other general mill information.
Specific details about the Desktop Mill itself, including information that is beyond the scope of this document, can be found at www.HaasCNC.com.
The Haas Desktop Mill is the ultimate training machine for schools and technical colleges.
Powered by a full-function Haas CNC control housed in our portable simulator enclosure, the Desktop Mill is perfect for teaching the basic principles of programming and operating a CNC mill.
Designed to cut plastics and machinable wax, it is also perfect for hobbyists and benchtop machinists.
Desktop Mill - Axis Definitions
  1. X-Axis
  2. Y-Axis
  3. Z-Axis
Desktop Mill - Exterior Views
  1. Operator Control
  2. Door
  3. Side Window
  4. Electrical box
  5. Air Vent / Fan
  1. Electrical Box Power
  2. Ethernet Connector
  3. Operator Control Power
  4. Fuse
  5. USB Port
Desktop Mill - Internal Top View
Image shows the Desktop Mill from the Top.
  1. Y- Axis Motor
  2. Y-Axis Home Sensor
  3. X-Axis Motor
  4. X-Axis Home Sensor
  5. Z-Axis Motor
  6. Z-Axis Home Sensor
  7. Spindle Cartridge
1.3 Specifications
Desktop Mill - Specifications
For Desktop Mill - Specifications, see the machine layout drawing for more info.
Desktop Mill - Layout Drawing
1.4 How to Use This Manual
To get the maximum benefit of your new Haas machine, read this manual thoroughly and refer to it often.
IMPORTANT:  Before you operate the machine, read and understand the Operator’s Manual Safety chapter.
DECLARATION OF WARNINGS
Throughout this manual, important statements are set off from the main text with an icon and an associated signal word: “Danger,” “Warning,” “Caution,” or “Note.” The icon and signal word indicate the severity of the condition or situation. Be sure to read these statements and take special care to follow the instructions.
Description Example
Danger means that there is a condition or situation that will cause death or severe injury if you do not follow the instructions given.  DANGER: No step. Risk of electrocution, bodily injury, or machine damage. Do not climb or stand on this area.
Warning means that there is a condition or situation that will cause moderate injury if you do not follow the instructions given.  WARNING:  Never put your hands between the tool changer and the spindle head.
Caution means that minor injury or machine damage could occur if you do not follow the instructions given. You may also have to start a procedure over if you do not follow the instructions in a caution statement. CAUTION: Power down the machine before you do maintenance tasks.
Note means that the text gives additional information, clarification, or helpful hints. NOTE:  Follow these guidelines if the machine is equipped with the optional extended Z-clearance table.
Description Text Example
Code Block text gives program examples. G00 G90 G54 X0. Y0.;
A Control Button Reference gives the name of a control key or button that you are to press.  Press [CYCLE START].
A File Path describes a sequence of file system directories.  Service > Documents and Software >...
A Mode Reference describes a machine mode.  MDI
A Screen Element describes an object on the machine’s display that you interact with.  Select the SYSTEM tab.
System Output describes text that the machine control displays in response to your actions.  PROGRAM END
User Input describes text that you should enter into the machine control.  G04 P1.;
Variable n indicates a range of non-negative integers from 0 to 9. Dnn represents D00 through D99.
Desktop Mill production switched to a new design in June 2023.
Some but not all parts are interchangeable between older machines and their redesigned counterparts.
To identify which version of the Desktop Mill you are working on, look for the following key identifying features described below.
Desktop Mill Reboot Version
Production of Reboot Desktop Mills started in June 2023.
The most prominent difference between the two versions of the Desktop Mill is the thickness of the table.
The Reboot Version's table is 1.75" thick [1].
Desktop Mill Non-Reboot Version
Production of Non-Reboot Desktop Mills ended in June 2023.
The Non-Reboot Version's table is 0.75" thick [2].
