8 - Desktop Mill - M-Codes
Desktop Mill - Operator's Manual Supplement
  • 0 - Desktop Mill - Table of Contents
  • 1 - Desktop Mill - Introduction
  • 2 - Desktop Mill - Legal Information
  • 3 - Desktop Mill - Safety
  • 4 - Desktop Mill - Installation
  • 5 - Desktop Mill - Control Icons
  • 6 - Desktop Mill - Operation
  • 7 - Desktop Mill - G-Codes
  • 8 - Desktop Mill - M-Codes
  • 9 - Desktop Mill - Settings
  • 10 - Desktop Mill - Maintenance
  • 11 - Desktop Mill - Troubleshooting
  • 8.1 Mill - M-Codes
8.1 Desktop Mill - M-Codes
This page gives detailed descriptions of the M-codes that you use to program your machine.
CAUTION: The sample programs in this manual have been tested for accuracy, but they are for illustrative purposes only. The programs do not define tools, offsets, or materials. They do not describe workholding or other fixturing. If you choose to run a sample program on your machine, do so in Graphics mode. Always follow safe machining practices when you run an unfamiliar program.
NOTE: The sample programs in this manual represent a very conservative programming style. The samples are intended to demonstrate safe and reliable programs, and they are not necessarily the fastest or most efficient way to operate a machine. The sample programs use G-codes that you might choose not to use in more efficient programs.
M-codes are miscellaneous machine commands that do not command axis motion. The format for an M-code is the letter M followed by two to three digits; for example M03. Only one M-code is allowed per line of code. All M-codes take effect at the end of the block.
Desktop Mill Minimum Spindle Speed
When using M02 or M03, do not command the spindle to run less than 1500 RPM.
Warning: The Desktop Mill's Spindle should not be run slower than 1500 RPM. At low speeds, the VFD that controls the will supply too much current to the spindle motor. This high current will damage the spindle and eventually cause it to fail.
HSG-A 02-28-2024
M - Code Description
M00 Stop Program
M01 Optional Program Stop
M02 Program End
M03 Spindle Foward Command
M04 Spindle Reverse Command
M05 Spindle Stop Command
M06 Tool Change
M07 Shower Coolant On
M08 / M09 Coolant On / Off
M10 / M11 Engage / Release 4th Axis Brake
M12 / M13 Engage / Release 5th Axis Brake
M16 Tool Change
M19 Orient Spindle
M30 Program End and Reset
M31 Chip Conveyor Forward
M33 Chip Conveyor Stop
M34 Coolant Increment
M35 Coolant Decrement
M36 Pallet Part Ready
M39 Rotate Tool Turret
M41 / M42 Low / High Gear Override
M46 Qn Pmm Jump to Line
M48 Validate That The Current Program is Appropriate for Loaded Pallet
M50 Pallet Change Sequence
M51-M55 Set Optional User M-codes
M61-M65 Clear Optional User M-codes
M70/M71 Workholding Clamp / Unclamp
M73 / M74 Tool Air Blast (TAB) On / Off
M75 Set G35 or G136 Reference Point
M78 Alarm if Skip Signal Found
M79 Alarm if Skip Signal Not Found
M80 / M81 Auto Door Open / Close
M82 Tool Unclamp
M83 / M84 Auto Air Gun On / Off
M86 Tool Clamp
M88 / M89 Through-Spindle Coolant On / Off
M90 / M91 Fixture Clamp Input On / Off
M95 Sleep Mode
M96 Jump If No Input
M97 Local Sub-Program Call
M98 Sub-Program Call
M99 Sub-Program Return or Loop
M104 / M105 Probe Arm Extend/ Retract
M109 Interactive User Input
M116 / M117 Vise Air Chips Blast On/Off
M130 / M131 Display Media / Cancel Display Media
M138 / M139 Spindle Speed Variation On/Off
M158 / M159 Mist Condenser On/Off
M160 Cancel Active PulseJet
M161 PulseJet Continuous Mode
M162 PulseJet Single Event Mode
M163 PulseJet Modal Mode
M180 / M181 Auto Window Open / Close
M199 Pallet / Part Load or Program End
M300 M300 - APL/Robot Custom Sequence
