1 - VMT - Introduction
Vertical Mill/Turn Operator's/Service Manual
  • 1 - VMT - Introduction
  • 2 - VMT - Legal Information
  • 3 - VMT - Installation
  • 4 - VMT - Operation
  • 5 - VMT - Control Icons
  • 6 - VMT - Programming
  • 7 - VMT - Offsets
  • 8 - VMT - G-Codes
  • 9 - VMT - M-Codes
  • 10 - VMT - Settings
  • 11 - VMT - Probing
  • 12 - VMT - MRZP
  • 13 - VMT - Maintenance
  • 1.1 Introduction
  • 1.2 Axis Definitions
  • 1.3 How To Use This Manual
1.1 Introduction
Overview
This operator’s manual supplement describes the unique features and functions of the VMT. Refer to your Mill Operator’s Manual for control operation, programming, and other general mill information.
Specific details about the VMT itself, including information that is beyond the scope of this document, can be found at www.HaasCNC.com.
Many industries today, especially aerospace and automotive design, rely on multi-axis machining to speed manufacturing processes and increase accuracy.
The ability to mill and turn complex parts in a single setup reduces tooling costs and labor time, while simplifying production and increasing part consistency.
VMT-750 Axis Definitions
This diagram illustrates the axes available on the VMT-750.
How to Use This Manual
To get the maximum benefit of your new Haas machine, read this manual thoroughly and refer to it often.
IMPORTANT:  Before you operate the machine, read and understand the Operator’s Manual Safety chapter.
DECLARATION OF WARNINGS
Throughout this manual, important statements are set off from the main text with an icon and an associated signal word: “Danger,” “Warning,” “Caution,” or “Note.” The icon and signal word indicate the severity of the condition or situation. Be sure to read these statements and take special care to follow the instructions.
Description Example
Danger means that there is a condition or situation that will cause death or severe injury if you do not follow the instructions given.  DANGER: No step. Risk of electrocution, bodily injury, or machine damage. Do not climb or stand on this area.
Warning means that there is a condition or situation that will cause moderate injury if you do not follow the instructions given.  WARNING:  Never put your hands between the tool changer and the spindle head.
Caution means that minor injury or machine damage could occur if you do not follow the instructions given. You may also have to start a procedure over if you do not follow the instructions in a caution statement. CAUTION: Power down the machine before you do maintenance tasks.
Note means that the text gives additional information, clarification, or helpful hints. NOTE:  Follow these guidelines if the machine is equipped with the optional extended Z-clearance table.
Description Text Example
Code Block text gives program examples. G00 G90 G54 X0. Y0.;
A Control Button Reference gives the name of a control key or button that you are to press.  Press [CYCLE START].
A File Path describes a sequence of file system directories.  Service > Documents and Software >...
A Mode Reference describes a machine mode.  MDI
A Screen Element describes an object on the machine’s display that you interact with.  Select the SYSTEM tab.
System Output describes text that the machine control displays in response to your actions.  PROGRAM END
User Input describes text that you should enter into the machine control.  G04 P1.;
Variable n indicates a range of non-negative integers from 0 to 9. Dnn represents D00 through D99.
