3 - VMT - Installation
Vertical Mill/Turn Operator's/Service Manual
  • 1 - VMT - Introduction
  • 2 - VMT - Legal Information
  • 3 - VMT - Installation
  • 4 - VMT - Operation
  • 5 - VMT - Control Icons
  • 6 - VMT - Programming
  • 7 - VMT - Offsets
  • 8 - VMT - G-Codes
  • 9 - VMT - M-Codes
  • 10 - VMT - Settings
  • 11 - VMT - Probing
  • 12 - VMT - MRZP
  • 13 - VMT - Maintenance
  • 3.1 VMT - Installation
  • 3.2 VMT - Anchoring
Under Construction
This procedure will guide you through the installation of a VMT-750
Tools required:
  • Precision Machinist Level, 0.0005" Division
  • Precision Spindle Test Bar, 8" Long - See the HSK - Spindle - Troubleshooting Guide for HSK tools.
  • 3/4 " socket and ratchet
  • 1-1/2" Wrench
  • Tape Measure
  • 0.0005" or 1 micron indicator
  • For 110V machines: 110V Electrical receptacle tester with GFCI diagnosis
  • For 240V machines: 240V Electrical receptacle tester with GFCI diagnosis
Leveling Screws Hardware
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Removal of Rust Inhibitor
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
Electrical Connections
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
Removal of Shipping Brackets
  • Remove the zip tie holding the chip auger in place and remove the auger [1]
  • Remove the cardboard tubing used to protect the auger. [2]
  • Remove the bracket and cardboard protecting the cable guide on top of the machine [3,4]
         Note: For large VMCs There is no bracket removal needed only cardboard removal.
  • Remove the Shipping brackets keeping the doors in place. [5,6,7,8]
  • Now that you have access, install the chip auger.
For a guide on chip auger installation please see:
VF 1-5 Chip Auger Installation
Power up the machine Jog without Zero Return and jog the X-axis upward.
Remove the spindle bracket.
Remove the rotary shipping bracket.
Remove and discard shipping hardware and install attached hardware.
Install the Rotary Sheet metal[1] and X-axis waycover[2].
HPU Installation
Remove the HPU mounting hardware except the two screws to hang the HPU[1].
Install the coolant washdown fitting to the front skirt[2].
Feed the HPU cables and hoses through the access hole[3].
Lift the HPU with a pallet jack and hang the HPU from front of machine. Install the remaining hardware[4].
Connect the drain hose to the fitting on the front of the machine[1].
Connect the cable to the junction box for the temperature sensor and float level sensor[2].
Connect the quick connect fittings to the HPU block[3]. Follow the color code zip ties.
Connect the solenoid cables to the solenoids[4]. Follow the color code zip ties.
Connect the HPU motor cable[5].
Machine Leveling
  • Adjust the four corner leveling screws to the same height to lift the base casting 3-1/2" from the ground.
  • Loosen the middle leveling screws [3, 6] so that they are not touching the pads, install jam nuts [1] on leveling screws, but do not tighten
  • Jog the table so that it is centered in the machine.
  • Place the level on the center of the bed and position it so that the shorter vial is parallel to the Y-axis and the longer vial is parallel to the X-axis.
  • Using the shorter vial adjust the front to back level by either adjusting the front or back leveling screws.
  • Adjust the leveling screws until the Y-axis bubble is centered.
  • Using the longer vial which is parallel to the X-axis, raise the leveling screws on lower side of the machine.
  • Adjust the leveling screws accordingly until the X-axis bubble is centered
  • Continue using the longer vial, with the table at the front of the machine look at the position of the indicating bubble
  • Jog the table through its full Y-axis travel stopping at the column, with the table at the column look to see which rear corner of the machine is lowest if any.
  • If needed adjust the leveling screws 2 and 4 until there is no twist across Y axis
  • Continue adjusting the level at the front and back of the machine until both readings are zero.
  • Lower the center leveling screws 3 and 6 until they make contact with the pads. Tighten these hand tight and then tighten them an additional 10 degrees with the ratchet.
  • Place the level in the center of the bed and orient it so the long vial is parallel to the Y-axis
  • Look at the bubble position when the bed is at its center position and then jog the bed back in the Y direction until it reaches the column.
  • Take note of the bubble position, if the level shows that the machine is either bowed in the up or down direction, make small and even adjustments to middle leveling screws 3 and 6
  • The Tolerance for both the twist and bow is N.T.E 0.0002"/10"
For a more in depth guide on how to level your VMC including how to level machines with outriggers please see:
VMC Leveling
Spindle Sweep
Tools Required:
  • Test Indicator with a magnetic mount.
  •  pH-neutral cleaner
  • Degreaser
  • Abrasive pad
  • Gauge Block (optional)
  • Clean the table surface to remove any corrosion
  • Jog the spindle down to the middle of the z-axis travel and attach the magnetic base to the spindle
  • Adjust the indicator to measure a 10" diameter circle
  • Position the table so that the indicator will remain on the table as the spindle rotates
  • Move the Z-axis so that the indicator makes contact with the table and zero the indicator
  • Sweep the spindle and take measurements every 90 degrees. Make sure the measurement locations are parallel to their respective axis
  •  The total indicator for all four positions should not exceed 0.0005"
Spindle Sweep Adjustment
 Note: Only the front and back sweep values can be effectively changed by adjustment of the middle leveling screws
  • If the values from the front to back differ by more than 0.0005", make small and equal adjustments to the middle leveling screws.
  • If the spindle sweep values come back into tolerance with only small adjustments to the leveling screws then there is no need to recheck the twist and bow.
For a more in depth guide on how to perform a spindle sweep test on your VMC please see:
VMC Spindle Sweep
B-AXIS PERPENDICULAR TO X/Y PLANE
Rotate the B-Axis to 0°. Measure 6" away from spindle nose. Mark the point on the test bar with a felt tip marker and place your indicator and set it to zero at the marked point.
Rotate the B-Axis to -45°. Without moving the indicator jog the X and Z-Axis to the marked point on the test bar. Make sure there is no movement in the Y- Axis.
Rotate the B-Axis to -90°. Without moving the indicator jog the x and Z-axis to the marked point on the test bar. Make sure there is no movementin the Y- Axis.
B-90° CONCENTRICITY TO SPINDLE
Mount a coaxial indicator to a HSKA63 ER-32 collet chuck and install to the spindle at B-90°. Sweep the spindle taper.
MRZP Offsets Settings & Safe Zones Calibration
Perform the MRZP Offsets Settings procedure and set the Safe Zones using the VPS templates.
VMT-750 MRZP Calibration
VMT-750 Safe Zone Calibration
VMT-750 - ATP Calibration
Perform the VMT ATP Calibration procedure using the VPS templates.
VMT-750 - WIPS Calibration
Perform the VMT WIPS Calibration procedure using the VPS templates.
Complete & Submit Inspection Report
Complete an inspection report after leveling, verifying geometry, setting the MRZP Offsets, and Safe Zone Calibration.
The Inspection Report EA0438 can be found on the Haas Service Guide.
Note: This site is available only to Haas Service Techs.
Email the completed inspection report to [email protected]. This will be attached to the machine history.
Lubrication Verification
Run the spindle run-in program.
 Note: For 10K spindles and above use a balanced tool holder
Examine the sight glass, make sure the correct number of drops are fall through the sight glass.
Examine the fittings [1,2] on top of the oil pump tank.
The oil collects on top of the oil pump tank [3] either behind or in front of the sight glass bracket, underneath the leaking fitting.
Tighten any leaking fittings.
Go to the Maintenance tab.
Press [F2] to cycle an axis lubrication test.
Inspect the gauge on the lubrication system.  Make sure it holds pressure.
Pendant Installation
After removing the pendant from its packaging you can now install it on your machine. For a pendant installation guide please see:
VMC Pendant Installation
Option Installation Guides
Verify and test that all the options have been properly installed.
Remote Jog Handle (RJH-Touch) - Installation
Wi-Fi Camera Option Installation
VMC Convenience Package
Auxilary Coolant Filter
CABCOOL installation
Pulsejet Installation
HAAS Oil Skimmer
Table work light
Auto Air Gun
Tool Air Blast
Machine Operation
Test Spindle Operation
  • Run Spindle Run in program 009221 located in the 009000 folder.
  •  In the case of unusual spindle noise run a vibration test
For a guide on how to perform a spindle vibration test please see:
Vibration Analysis - Ethernet Interface
Vibration Analysis - RS-232 Interface
Test Coolant Operation
  • Connect the Coolant pump and if your machine is came with the TSC option also connect the TSC pump
  • Test the flood coolant operation by pressing the [Coolant] button on the control  [1]
  • For TSC machines test the TSC coolant operation by pressing the [AUX CLNT] button on the control  [2]
Test Chip Auger Operation
  • Test the chip auger by cycling between the  [CHIP FWD],  [CHIP STOP], and [CHIP REV] buttons
Test Remote Jog Handle (RJH-Touch)
If your machine came with the remote jog handle option:
  • Attach the holster to the machine using the provided hardware
  • Hang RJH on holster
  • On the Control Pendant, press [MDI] and then [HAND JOG]. (Image 2)
  • Verify that the jog wheel on the Control Pendant works properly while RJH is docked
  • Remove RJH HAND UNIT from the holster. Unit should power on
  • Calibrate Touchscreen
  • Refer to Image 1 for the following
    • Press in the middle of the touch screen, an overlay should appear
    • Select the jog rate by pressing [LEFT] or [RIGHT] on the screen
    • Select an axis by pressing [-] or [+] on the screen
    • Exit the overlay by pressing the [X]
    • Jog X, Y, and Z with the jog wheel on the RJH
  • Use RJH key pad to jog X,Y, and Z axes in positive and negative directions
  • Repeat using Rapid Jog
Test Door Interlocks
  • Press [MDI]. Type in S500 M3; Press [ENTER]. Make sure the machine IS NOT in SETUP MODE by Checking the KEY SWITCH on the side of the pendant
    • With the door open, press [CYCLE START]. The machine should say to close the door and press CYCLE START
    • With the door closed, press [CYCLE START]. The INTERLOCK PIN should extend and the spindle starts rotating
      • While the locks are on try to open the doors
      • The spindle should not stop rotating but if the spindle stops, contact Haas for support
Test Through Spindle Air Blast (TAB)
If your machine came with the TAB option:
Note: PERFORM THIS AFTER TESTING TSC
  • Press [MDI] and type the following
                    M73;
                    S[insert max spindle speed here] M03;
                    G04 P60. ;
                    M30. ;
  • Press [CYCLE START]
  • Verify that full air line pressure blows out of the tool.
    • This should be similar to the air blow gun pressure.
Test Auto Air Gun (AAG)
If your machine came with the AAG option:
  • Press [MDI] and type M83; and press [Enter]
  • Check AAG for proper function, check solenoid for leaks in the CALM cabinet.
  • In [MDI] type M84; then press [CYCLE START] to de-activate the AAG.
Servo Auto Door. Product of Haas CNC machine tools.
Test Auto Door
If your machine came with the Auto Door option:
  • Verify the following:
    • Zero return U-axis
    • Setting - 131 auto door should be set to ON
  • Press [MDI] and type S300 M03; and press [CYCLE START]
  • Try to pull door open, The door gap is not to exceed 0.25”.
  • If the machine alarms out, does not close properly, closes hard, or the door gap exceeds 0.25" contact Haas for support
Z-axis tool change offset parameter
For a guide on how to check the Z-axis tool change offset parameter for either side mount tool changers or umbrella style tool changers please see:
SMTC - Z-Axis Tool Change Offset
UTC- Z-AXIS TOOL CHANGE OFFSET
Test Safety Features
  • Turn the (Run / Set-up) key switch to the Set-up mode
  • Test Memory Lock switch by verifying that in the ON position changes cannot be made to settings or programs.
  • Press [MDI] and type M03 S500;
  • Open door. Press [CYCLE START]  the spindle should not start.
  • Close door. Press [CYCLE START]  the spindle should start.
  • Verify door cannot be opened when spindle is running
  •  Verify door can open when spindle is off.
  • Verify that a window latch is installed on each side window and test that they hold the windows up in their lock positions
  • Verify that the windows lock close in the down position.
  • For 110V machines conduct a GFCI Test with a 110V GFCI tester at the plug point on the side of the control
  • For 240V machines  conduct a GFCI test with a 240V GFCI tester at the coolant pump connector
3.2 VMT - Anchoring
This procedure will show you how to install the Drop-In expansion style anchors to a Haas CNC.
NOTE: If the machine was built before Jan 2020 or is a VS or HDC series machine, please refer to the epoxy style anchoring procedure (AD0212) click here.
For instructions on how to anchor the various components for the Haas Cobot kits refer to the Haas Cobot - Anchoring instruction page.
This procedure applies to the following Service Kits:
Mill
Model Part Number
DC-1 93-1001018
DC-2 93-1001019
DC-4 93-1001211
DT/DM-1, DT/DM-2 93-1000601
DT/DM-3 93-1001136
EC-400/VC-400
93-1000567
See Note Below
EC-500/50 93-1001145
EC-1600/UMC-1600H 93-1000535
EC-630 93-1000856
GM-1 93-1001115
GM-1XT 93-1001235
GM-2-3AX 93-1000574
GM-2-5AX 93-1000542
GR-510 93-1000574
GR-712 93-1000574
MM/SMM Reboot 93-1001016
UMC-350HD 93-1000780
UMC-400/SS 93-1001224
UMC-500/SS 93-1000379
UMC-750/SS (NON REBOOT) 93-1000380
UMC-750/SS (REBOOT)  93-1001324
UMC-1000/SS (REBOOT) 93-1001324
UMC-1250/SS 93-1000644
UMC-1500-DUO/SS-DUO 93-1000871
VF-1/2, VF-2TR, VF-2SS 93-1000534
VF-2YT, VF-2SSYT, VM-2 93-1000549
 VF-3/3SS, VF-4/4SS 93-1000550
VF-3YT/3YTSS, VF-3YT/50, VF-5/40, VF-5/40TR, VF-5/40XT, VF-5SS, VF-5/50, VF-5/50TR, VF-5/50XT, VM-3, VMT-750 93-1000548
VF-6/40, VF-6SS, VF-6/40TR, VF-7/40, VF-6/50, VF-6/50TR, VF-7/50, VM-6 (Base with 8 leveling feet) Built between January 2020 and September 6th 2023 93-1000547
VF-8/40, VF-9/40, VF-8/50, VF-9/50, VR-8, VR-9 (Base with 8 leveling feet) Built between January 2020 and October 6th 2023 93-1000546
VF-10/40, VF-12/40, VF-10/50, VF-12/50 (Base with 8 leveling feet) 93-1000545
VF-11/40, VF-11/50, VR-11 (Base with 8 leveling feet) 93-1000544
VF-6/6TR/6SS/7/10/12 both 40T & 50T and VM-6 (Base with 6 leveling feet) Built September 7th 2023 and later 93-1000999
VF-8/9/11/14 both 40T & 50T and VR-8/9/11/14 (Base with 6 leveling feet) Built October 7th 2023 and later 93-1001000
VS-3 93-1000870
Updated
Note: For EC-400 anchor kit 93-1000567 only. EC-400 Anchor Template 96-0286 only permits 7 of the 8 anchor locations to be utilized. The anchor spot under the front door is inaccessible due to improper enclosure spacing. This is corrected with EC-400 Anchor Template 96-0286A, which shifts the front anchor location to a more accessible spot.
Pallet Pool/RPL
Model Part Number
UMC-500PP 93-3526
UMC-750PP (V1) See Note Below
UMC-750PP (V2) 93-3527
UMC-1000PP (V2) 93-3527
UMC-1250PP See Note Below
EC-400PP 93-3525
VF-2YTPP See Note Below
VF-4 PP See Note Below
Robot Pallet Loader See Note Below
Note: There is currently no 93-xxxx service kit for the following models:
  • (30-12644B + 96-0316A) UMC-750 Pallet Pool (V1)
  • (30-12644B + 96-0364) VF-2YT Pallet Pool
  • (30-12644B + 96-0383) VF-4 Pallet Pool
  • (30-12644B + 96-0388) Robot Pallet Loader
You would need to order individual parts,  please contact your Local Haas Factory Outlet for availability.
Lathe
Model Part Number
ST-10/10Y/15/15Y 93-1000378
ST-10L/10LY/15L/15LY 93-1000855
ST-20/25/20Y/25Y 93-1000552
ST-20L/20LY/25L/25LY/28L/28LY 93-1001005
ST-30/35/30Y/35Y, DS-30Y (REBOOT ONLY) 93-1000541
ST-30L/35L/LY 93-1001079
ST-40 93-1000540
ST-40/40Y (Reboot) 93-1000819
ST-40L 93-1000539
ST-40L (Reboot) 93-1000820
ST-40S/45S/SY  93-1001012
ST-50/55 93-1000538
TL-1 93-1000537
TL-2 93-1000536
Extended Liner System
ST-10/10L/10Y/10LY 93-1000844
93-1000845
Tools required:
  • Paint markers
  • Painters Tape
  • Pipe cleaner brush
  • 5 lb. Sledge Hammer
  • SDS Plus Hammer Drill
    Note:  The SDS-Plus Hammer drill should be rated for 1" bit.
Video Instructions
Anchor Template Placement
  1. Unroll machine anchoring template [1].
  2. Use centerlines and provided reference sheet dimensions, measure distances to nearest allowable obstructions.
  3. Once position is established, taped the corners [2] of the anchoring template to the foundation.  Keep the template as flat as possible.
  4. Spray paint the foundation in the cutout areas of the template [3].
  5. Let the paint dry for 5-10 minutes.
  6. Remove the anchoring template [1].
Drill Holes and Set the Anchors
Use the provided SDS-Plus Style drill for the following steps:
  • Drill specified number of 5/8" holes at depth 2.00 - 2.25" each.
    • Drill bit should be perpendicular to foundation.
  • Clean the holes with pipe cleaner.
  • Use compressed air and a vacuum to clear holes.
  • Repeat for the number of leveling pads.
  • Cover the holes with tape to protect from unwanted debris while the other holes are drilled.
  • Using the hammer [2] set the drop-in anchor [1] flush with the concrete [3].
    Note:  Do not use the set tool to drive the anchor.
  • Use the provided setting tool [1] and hammer [2], to seat the anchor in the concrete.
  • Make sure that the anchors are seated flush [3], use the setting tool as a gauge.
    Note:  Be careful not to overdrive the anchor [4] to far inside the hole.
Machine Placement
  1. Once the anchors are set, place the leveling pads on the spray painted cross-hairs.
  2. Place the machine on the leveling pads.
  3. Set the machine height.
  4. Level the machine
  5. Tighten down the machine locknuts.
Anchoring Strap Installation
  1. Place the thrust plate flush [1] with the foundation.
  2. Thread stud [2] into the anchor location using two lock nuts.
  3. Place 1/2-13 hex nut on the 1/2-13 hex bolt [3] on top of the thrust plate.
  4. Place the anchoring strap [4].
  5. Place the washer [5] on the threaded rod.
  6. Thread the 1/2-13 hex nut [6] into the threaded rod.
  7. Be sure the anchoring strap [7] remains parallel to the clamped casting surface.
  8. Torque 1/2-13 hex nut to 25ft-lbs (34 nm).
Make sure that the anchor strap [1] is level on the hex nut [2] and the machine base [3].
NOTE: Make sure the threaded stud [4] is perpendicular to the floor and not bent.
Make sure the threaded stud welded to the base is not bent as shown in the image [1].
If this occurs make sure that the anchor holes are drilled straight and re-drill them if necessary.
If there is clearance on the anchor [1] and stud [2] place the end caps [3] on the ends as shown in the image. Place these caps on all all anchors.
NOTE: The UMC-1250/SS does not have the anchoring fingers on the base foot. The indicated holes on the anchoring layout will have them anchoring down the base flange as shown in the image. Image [1] is the front of the machine, while image [2] is the back of the machine.
