12 - VMT - MRZP
Vertical Mill/Turn Operator's/Service Manual
  • 1 - VMT - Introduction
  • 2 - VMT - Legal Information
  • 3 - VMT - Installation
  • 4 - VMT - Operation
  • 5 - VMT - Control Icons
  • 6 - VMT - Programming
  • 7 - VMT - Offsets
  • 8 - VMT - G-Codes
  • 9 - VMT - M-Codes
  • 10 - VMT - Settings
  • 11 - VMT - Probing
  • 12 - VMT - MRZP
  • 13 - VMT - Maintenance
  • 12.1 MRZP Calibration
  • 12.2 Safe Zone Calibration
MRZP Settings
This tells you how to set Machine Rotary Zero Point (MRZP) Offsets.
This procedures shows images that use both calibration assemblies.
 Important: The spindle probe must be calibrated before doing this procedure. This makes sure the accuracy of the probe to the machine position is correct. Refer to the Next Generation Control - Probe Calibration (VPS) procedure, in the diy.haascnc.com
To create the MRZP Artifact you will need the necessary tools to face and turn an OD diameter. Round stock is needed to create the gauge ring. Recommended dimensions are Ø2.0” and 6.0” in length.
Press [EDIT] and go to the VPS tab. Once there using the direction buttons highlight  the probing directory and press [RIGHT ARROW].
Once there highlight CALIBRATION and press [RIGHT ARROW].
Highlight MRZP CALIBRATION  and press [RIGHT ARROW].
Highlight MRZP VMT-750 and press [RIGHT ARROW].
Machine the face and turn the diameter to clean up 100%.
 Note: Leave the machined artifact clamped in the chuck. This will used for the MRZP setup.
Dimension the MRZP artifact's OD using the proper measuring tools and enter the value. The precision of the tool should at least be 0.0001”.
Note: Do not remove the part from the chuck to measure the part. Doing so will cause the part to not be aligned to Spindle Center Line.
Follow the probe position description at the bottom of the window.
Jog the Y-Axis to Spindle Centerline.
Jog the X-Axis to 0.250" above the part.
Jog the Z-Axis to 0.250" from the edge of the part.
Press [F4] to populate the program to MDI and go over the program, before pressing  [CYCLE START].
Press [SETTING] and verify settings 300, 302, and 303 are populated.
This tells you how to set Safe Zone Offsets.
Highlight SAFE ZONES and press [RIGHT ARROW].
Highlight SAFE ZONES VMT-750 and press [RIGHT ARROW].
Dimension the chuck's OD using the proper measuring tools and enter the value. The precision of the tool should at least be 0.0001”.
Manually rotate the chuck so the probe tip clears the master jaws.
Jog the X-Axis to 0.250" above the chuck.
Jog the Z-Axis to 0.250" from the edge of the chuck.
Press [SETTING] and verify settings 387, 379, and 380 are populated.
