11 - VMT - Probing
Vertical Mill/Turn Operator's/Service Manual
  • 1 - VMT - Introduction
  • 2 - VMT - Legal Information
  • 3 - VMT - Installation
  • 4 - VMT - Operation
  • 5 - VMT - Control Icons
  • 6 - VMT - Programming
  • 7 - VMT - Offsets
  • 8 - VMT - G-Codes
  • 9 - VMT - M-Codes
  • 10 - VMT - Settings
  • 11 - VMT - Probing
  • 12 - VMT - MRZP
  • 13 - VMT - Maintenance
  • 11.1 VMT - ATP/WIPS Calibration
This tells you how to calibrate the Automatic Tool Presetter on a VMT-750.
This procedures shows images that use both calibration assemblies.
 Important: The spindle probe must be calibrated before doing this procedure. This makes sure the accuracy of the probe to the machine position is correct. Refer to the Next Generation Control - Probe Calibration (VPS) procedure, in the diy.haascnc.com
Press [EDIT] and go to the VPS tab. Once there using the direction buttons highlight the PROBING directory and press [RIGHT ARROW].
Once there highlight CALIBRATION and press [RIGHT ARROW].
Highlight Step 1 (Tool Probe Calibration VMT) and press [RIGHT ARROW].
Load a calibration tool of known gauge length and diameter into the spindle and select the Tool Number for the calibration tool.
Note: Current active TOOL NUMBER is default.
Press [F2] to open the Mechanisms popup. Select the probe arm and press [F2] to extend the probe arm.
Follow the probe position description at the bottom of the window.
Jog the X, Y, and Z-Axis to position the calibration tool 0.25 inches (7mm) above the tool probe.
The length is taken from the tool's X Geometry value on the Tool Offset table.
Enter the Calibration Tool diameter.
Press [F4] to generate Gcode or press [CYCLE START] to run the progam in MDI.
Highlight Step 2 (Spindle probe length calibration VMT) and press [RIGHT ARROW].
Load the spindle probe tool into the spindle and select the Tool Number for the probe tool.
Enter the diamter of the spindle probe tip. Default is 6mm or 0.2632 inches.
Spindle probe will touch on the X+ of the probe square.
13
14
Jog the X, Y, and Z-Axis to position the spindle probe 0.2 inches (5mm) above the tool probe.
