4 - VMT - Operation
Vertical Mill/Turn Operator's/Service Manual
  • 1 - VMT - Introduction
  • 2 - VMT - Legal Information
  • 3 - VMT - Installation
  • 4 - VMT - Operation
  • 5 - VMT - Control Icons
  • 6 - VMT - Programming
  • 7 - VMT - Offsets
  • 8 - VMT - G-Codes
  • 9 - VMT - M-Codes
  • 10 - VMT - Settings
  • 11 - VMT - Probing
  • 12 - VMT - MRZP
  • 13 - VMT - Maintenance
  • 4.1 VMT - Power Up / Zero Return
  • 4.2 VMT - Tool Type
  • 4.3 VMT - Tool Change
4.1 VMT - POWER UP / ZERO RETURN
VMT Power Up / Zero Return
After the machine is powered on cycle the door and the [EMERGENCY STOP] button. Then press [POWER UP].
The Zero Return popup will appear. If the machine is in a safe position press A and the VMT will zero return the axes in the following order:
  1. X
  2. B (4th axis)
  3. Y , Z, TC arm and Tool Turret
4.2 VMT - TOOL TYPE
VMT - Tool Type
The Tool Type needs to be specified for each tool. The options are:
Mill
Lathe
4.3 VMT - TOOL CHANGE
VMT - Tool Change
T101 M06 selects the tool, the offset 1, and commands the tool change to Tool 1.
