Through-Tool Air Blast - Installation - Compensating TSC - VMC - AD0457
Service Home How To Procedures Through-Tool Air Blast - Installation - Compensating TSC - VMC - AD0457
15.2 TAB - Installation - NGC
Recently Updated Last updated: 05/16/2023
VMC - Compensating TSC - Through-Tool Air Blast - Installation - NGC
AD0457
This procedure tells you how to install Through-Tool Air Blast (TAB). Perform this procedure on mills:
Machine Compatibility:
  • Made after 2018
  • With a compensating union
  • With a pipe fitting TSC manifold
  • Set setting 32 COOLANT OVERRIDE to NORMAL
  • Machine must be equipped with one of the following:
    • Full TSC option
    • TSC READY and software 100.22.000.1000 or later
 Note: Machines built before June 2019 and have the Programmable Air/Dual Programmable Air or VF Small Auto Window option on their machine need to contact Haas Service to have a patch applied to enable the TAB option.
This procedure applies to the following service kit:
  • 93-1000323 TOOL AIR BLAST NGC MC W/COMPENSATING
Through-Tool Air Blast - Installation - VMC
Turn off the machine air supply using the shutoff valve located at the bottom of the CALM cabinet.  Bleed off the residual air pressure using the pressure relief valve located above the shutoff valve.
Remove the plug [1] located under the pressure gauge on the CALM manifold.
Using the compression fitting [2] install the TAB solenoid [3].
Route the TAB solenoid power cable through the cable carriers to the plug labeled "TAB AIR" and plug it in.
Remove the enclosure panel from spindle head and locate the TSC manifold.
NOTE: There are two types of TABs--the spring & ball [A] and the shuttle & ball [B].
Remove the plug [1] from the top of the TSC manifold.
Install the push-to-connect fitting [2] onto the TSC manifold.
Route the clear hose from the TAB solenoid though the cable carriers to the TSC manifold.
Spring & Ball Hose Routing
Connect air hose from TAB air check valve [1] into the top of the TAB manifold.
Connect air hose from TRP air blast [2] and TSC purge valve [3] into the TAB manifold.
Connect coolant hose from TSC pump [4] into TAB check valve input.
Connect coolant hose from TAB check valve output into the compensating union [5].
Shuttle & Ball Hose Routing
IMPORTANT: The TAB check valve coolant input and output are flipped from the spring & ball TAB check valve.
Follow the NGC PATCH FILE Installation procedure to download the required patches:
  • Parameter Configuration Patch
  • I/O Configuration Patch
TAB Test
Make sure the TAB system operates correctly. Operate this code in MDI mode:
M73;
G04 P5.;
M74;
G04 P3.;
M99;
M73 starts the TAB. M74 stops the TAB.
Manually operate the TAB:
Press [SHIFT]. Press [AUX CLNT].
The tool air blast starts.
The tool air blast stops.
