UMC - B-Axis and C-Axis Intersection Tool
Install the B Axis and C Axis intersection tool:
Jog the C Axis to 0°.
Push [EMERGENCY STOP].
Clean the table.
Guide the shaft of the adapter [1] while you slowly lower it into the center bore.
Attach the adapter to the table with (2) screws [4] and (2) T-nuts.
Attach the alignment bar [2] to the adapter with (3) screws [3].
Snug the (3) screws to allow for adjustments in the next step.
Align the B/C intersection tool with the C Axis:
Put an indicator on the front side of the alignment bar near the base.
Release the [EMERGENCY STOP]. Push [RESET] to clear any alarms.
Jog across the tool in the X Axis to find the high spot.
Set the indicator to 0.
Jog the C Axis 360°.
Lightly tap the base with a rubber mallet to adjust the radial error on the alignment bar.
Note: Adjust the alignment bar to half of the measured error, because you are measuring the diameter error.
When correctly adjusted the radial error is less than 0.0002" (0.005 mm).
Check the B/C intersection:
Center the indicator [1] on the front side of the alignment bar near the top of the cylinder.
Zero the indicator.
Turn the (3) screws [2] on the alignment bar to adjust the runout.
Repeat Step 2 and verify the alignment did not change.
