Active Ballscrew Compensation - Calibration
Service Home How To Procedures Active Ballscrew Compensation - Calibration
Recently Updated Last updated: 11/27/2023
- Jump to Section - 1. Introduction (2 steps) Back to Top
This procedure outlines how to calibrate the Active Ballscrew Compensation system.
Note: The system should be calibrated only after the machine has been idle for at least 5 hours so that the axis ballscrew is at room temperature.
A calibration should be done after any linear sensor part or ballscrew is replaced.
Important: It is recommended to run a calibration at machine install.
Calibration
Verify the linear sensor is enabled for each axis it is installed on, it should be set to SCALE_DELTA [1].
Note: This image shows all three axes enabled, only the axes that have the linear sensor should be enabled.
Perform the following steps for every axis with a linear sensor that needs calibration
  1. Navigate to the Factory Tab [1] under Diagnostic > Parameters.
  2. Search .364 [2] in the Factory Tab.
  3. Type in the Axis Letter and press F2 [3].
  4. A pop up [4] will show up asking if you would like to calibrate the linear sensor offset, press [Y].
After the axis has been calibrated the offset value will show up in the parameters [5].
