95 Gallon Coolant Tank - Installation - AD0852
Service Home How To Procedures 95 Gallon Coolant Tank - Installation - AD0852
Recently Updated Last updated: 06/26/2026
AD0852
Revision A - 06/2026
- Jump to Section - 1. Introduction 2. Installation (4 steps) Back to Top
Chips and Coolant 95 gallon tank. Product of Haas CNC machine tools.
This procedure shows how to install the 95 Gallon Coolant Tank.
This procedure applies to the following Service Kits:
  • 93-1000353 COOLANT OPTION W/AUGER GM-2
  • 93-1000396 COOLANT OPTION KIT GM-2 3AX
  • 93-1000397 COOLANT OPTION KIT GM-2 5AX
 Note: This procedure uses a GM-2 for illustrative purposes. These steps will apply to 95-Gallon Tank installations on other Machines.
Power off the machine.
Place the strainer basket [1] into the coolant tank [2].
Move the coolant tank assembly [2] under the drain slots at the base of the machine.
Note: Make sure that the strainer basket [1] is directly under the drain slots to ensure coolant flows into the tank.
Insert the coolant pump assembly [3] into the empty corner of the coolant tank, close to the handle.
Connect the hose from the coolant pump [1] to the coolant filter [2].
Install the CLNT PMP EXT CBL [1] in the control cabinet and route it to the coolant electrical connection bracket.
 Note: Machines not using 93-1000396 should have the CLNT PMP EXT CBL installed.
Connect the coolant pump power cable [2] to the CLNT PMP EXT CBL.
Fill the tank with the necessary gallons of coolant in order to fill the tank.
Install the coolant float sensor into the coolant tank. Refer to Coolant Float Sensor - NGC - Installation or Coolant Float Sensor - CHC - Installation for more information.
TSC Option:
Insert TSC pump assembly [1] into the coolant tank next to the coolant pump.
Connect the purple air hose from the TSC pump assembly's cylinder [2] and route into the CALM cabinet. Connect hose into TSC pump's solenoid.
Connect the TSC pump power cable [3] and TSC pressure sensor cable [4] into the machine's connectors.
