A616C or A65C Spindle Nose Installation - AD0970
Service Home How To Procedures A616C or A65C Spindle Nose Installation - AD0970
Recently Updated Last updated: 05/21/2026
A616C or A65C Spindle Nose - Installation
Revision 1
AD0970
Revision A - 05/2026
- Jump to Section - 1. Installation (3 steps) Back to Top
This document used to be called ES0180B.
Before installation of A616C or A65C spindle nose, ensure proper operation of A6AC collet closer (See A6AC instruction sheet ES-0176).
Installation kit includes:
  • A616C or A65C Spindle Nose
  • 6 SHCS
  • 4 Collet Keys (extra collet keys as backups and are not set to interface with collet)
  • 16C or 5C Collet adapter
  • 2 O-rings
Install A616C or A65C collet adapter into the A6AC drawbar, hand tighten until adapter bottoms out on drawbar.
Lubricate o-ring (installed on collet adapter) with a lightweight grease and install spindle nose over collet adapter face.
Align locating pin in A6 platter with mating hole in spindle nose and secure with the socket head cap screws (SHCS) supplied with kit.
Torque six SHCS in star pattern in incremental steps to 15, 35 & 50 ft/lbs.
Check taper runout after torque procedure to 0.0005”. If runout exceeds 0.0005” loosen SHCS on high side one increment and retorque SHCS on low side. Retorque all SHCS and recheck runout.
Operate drawbar to check for proper operation. (See operator’s manual for collet installation and troubleshooting)
Note: To tighten the joint between the adapter and the drawbar, insert a steel bar in the drawtube holes near the knurl to prevent drawt drawtube rotation, use a spanner wrench on the adapter and apply enough force to tighten the joint between the adapter and drawtube to prevent unthreading of this joint during normal collet adjustment/usage.
