C-Axis Motor Replacement - ST 15-30 Lathe - NGC - AD0420
Service Home How To Procedures C-Axis Motor Replacement - ST 15-30 Lathe - NGC - AD0420
Recently Updated Last updated: 12/22/2023
AD0420
- Jump to Section - 1. C-Axis Motor Replacement (2 steps) Back to Top
This procedure applies to service kit 93-2909 for C-axis motor replacement on ST-15 through ST-30 models.
Press [EMERGENCY STOP] and remove necessary sheetmetal (shaded in grey)  to access the C-axis servo motor.
Visually verify that the C-axis motor is disengaged. Use M155 to disengage if needed.
Unplug the motor and encoder cables.
Remove the four 5/16-18 socket head cap screws holding the motor onto the C-axis body and remove the C-axis motor.
Install the new motor and tighten the four socket head cap screws. Reference the Haas Fastener Torque Specifications. Plug in the motor and encoder cables.
IMPORTANT: All axis cables and connectors should have dielectric grease before connecting. If dielectric grease needs to be reapplied, make sure to only place grease on on the contact points of the connectors. Do not apply excess grease to the entire face of the connector. This can cause damage to the servo motor.
Perform the C-AXIS ENGAGEMENT OFFSET PROCEDURE
Reinstall the sheet metal panels that were removed.
