CM-1 Waycover - Replacement - AD0847
Service Home How To Procedures CM-1 Waycover - Replacement - AD0847
Recently Updated Last updated: 03/03/2026
CM-1 - Way Cover - Replacement
AD0847
Revision A - 3/2026
- Jump to Section - 1. Introduction 2. X and Y Way Cover Removal 3. X and Y Way Cover Installation Back to Top
This procedure demonstrates how to replace the X and Y way covers on CL-1 machines. To replace the way covers, you must order the correct kit. Go to the Way Cover - Troubleshooting Guide to troubleshoot the way covers.
Note: Pictures in this procedure are used for reference only.
Note: Make sure to clean any chips/deris from way covers before insalling new ones.
Note: This procedure is for both regular and stainless steal way covers.
The following procedure applies to the following service kit.
  • 93-1001204  - WAYCOVER FIELD INSTALL KIT CM-1
Jog machine to the middle of the X axis and jog Y axis all the way forward.
Remove [1] FBHCS 1/4 - 20 x 1/2 attaching table skirt to table. Image 1
Remove table skirt [1] ends and [2] sides. Image 2
Remove [1] linear guide shield brackets, along with shoudler bolts [2] 1/4 X 1/2 10-32 connected to spring and floater way cover.
Remove [1] BHCS 10-32 x 3/8 from Y axis back way cover.
Remove way cover.
Jog Y axis all the way back.
Remove [1] BHCS 10-32 x 3/8 from Y axis front way cover.
Remove [1] FBHCS 1/4 - 20 x 1/2 from Y axis front way cover.
Remove way cover.
Jog X axis to gain access to bolts if needed.
Remove bottom cover on X axis right side way cover. [1] BHCS 10-32 x 3/8.
Remove [2] FHCS 10- 32 x 1/2 from X axis right side way cover.
Remove way cover.
Remove [1] FHCS 10- 32 x 1/2 on X axis left side way cover.
Remove way cover.
Install X axis left side way cover with floater and spring attached.
Install [1] FHCS 10- 32 x 1/2.
Install X axis right side way cover along with floater cover and springs.
Install [2] FHCS 10- 32 x 1/2 for X axis right side way cover.
Install bottom cover on right side way cover. [1] BHCS 10-32 x 3/8.
Jog Y axis all the way forward, keeping X axis in the middle of travel.
Install Y axis back way cover.
Install [1] BHCS 10-32 x 3/8 for Z axis back way cover.
Install [1] BHCS 10-32 x 3/8 for Y axis back way cover.
Jog Y axis all the way back, keeping X axis in the middle of travel.
Install Y axis front way cover.
Install [1] FBHCS 1/4 - 20 x 1/2 for Z axis front way cover.
Install [1] BHCS 10-32 x 3/8.
Attach springs to shoulder bolts.
Install shoulder bolts [1] 1/4 X 1/2 10-32.
Install table skirt [1] ends and [2] sides. Image 1
Attach table skirt using [1] FBHCS 1/4 - 20 x 1/2. Image 2
