Haas Liquid Grease Filter Kit - AD0429
Service Home How To Procedures Haas Liquid Grease Filter Kit - AD0429
Recently Updated Last updated: 09/09/2022
Haas Liquid Grease - Filter Kit
AD0429
Applies to machines built from April, 2014 to August 2022
The grease lubrication system is a critical part of the Haas machine and it has very precise metering units at all of the lubrication points.  The slightest amount of contamination in the system can clog these fittings and will eventually cause damage to the linear motion components.  It is critical that the system stays clean every time the canister is refilled.  It is also critical that the pickup strainer is upgraded to the one currently used in production.  See detailed instructions below.
Install New Mesh Filter
  • Replace the filter if the pick-up tube has the 40 mesh 0.625" diameter filter [1]
  • Replace with 80 mesh 0.625" diameter filter (P/N 58-1993A) [2]
  • Remove grease canister [4]
  • Remove brass fitting [3] on end of pick-up tube [1]
  • Discard old 40 mesh filter [2]
  • Clean brass fitting
  • Clean any debris from the inside of the pick-up tube and any brass from the threads
  • Install new 80 mesh filter to the fitting [2]
  • Install fitting to the pick-up tube
  • Fill the HLG reservoir with compatible lubricant to 1/2" (13 mm) below the threads on the reservoir.
  • Prime the lube lines and verify each axis is getting grease
