OM-1 / OM-2 Positive Ventilation Kit - Spindle Head - Installation - AD0167
Service Home How To Procedures OM-1 / OM-2 Positive Ventilation Kit - Spindle Head - Installation - AD0167
Recently Updated Last updated: 08/08/2023
AD0167
Applies to machines built before: February, 2015
- Jump to Section - 1. Installation (5 steps) Back to Top
This procedure tells you how to install the positive ventilation kit. The kit includes a fan. The fan supplies positive air pressure to the spindle head. This keeps contamination out of the spindle head. Contamination decreases belt life.
OM Fan Kit, (P/N 93-0624)
Set the main circuit breaker to the OFF position. Lockout/Tagout the main circuit breaker.
Some Office Mill have an auxiliary fan [1]. The fan is attached to the base of the Z-Axis cable carrier. Remove the auxiliary fan.
Remove the power cable for the fan.
Discard the auxiliary fan and the cable.
Remove the rear enclosure panel [2].
Measure dimensions [A] and [B].
  • A - 4.70" (11.95 cm)
  • B - 17.90" (45.47 cm)
Mark the panel at [C].
Mark (5) circles on the rear panel. Use these dimensions:
  • C - center of the large circle
  • D- 0.187 (4.75 mm) diameter
  • E - 4.50" (11.40 cm) diameter
  • F - 2.07" (52.6 mm)
  • G - 4.130" (10.50 cm)
  • H - 4.130" (10.50 cm)
Use a jigsaw [1] to cut the largest hole.
Drill [2] the (4) remaining holes.
Attach the fan assembly to the rear panel.
Attach the rear panel [1] to the Office Mill.
Locate the receptacle at the rear of the control cabinet.
Connect the power cable [2] to the receptacle.
Wind the extra cable [3] into a coil.
Use a cable tie to hold the coil.
