Pallet-Pool Lifter Solenoid Valve Assembly - Replacement - EC-400PP - AD0149
Service Home How To Procedures Pallet-Pool Lifter Solenoid Valve Assembly - Replacement - EC-400PP - AD0149
Recently Updated Last updated: 12/01/2018
Lifter Solenoid Valve Assembly - Pallet-Pool - Replacement - EC-400PP
AD0149
Applies to machines built from: July, 2005 to August, 2014
- Jump to Section - 1. Lifter Solenoid Valve Assembly - Pallet-Pool - Removal (7 steps) 2. Lifter Solenoid Valve Assembly - Pallet-Pool - Installation (5 steps) Back to Top
Turn off the air.
[POWER OFF] the machine.
Lockout/tagout the main circuit breaker.
Remove the (16) screws [1] from the cover on the slider casting.
Remove the (4) cable carrier screws [1] and the cable carrier [2].
Remove the slider casting cover [1].
Remove the main air tube [1].
Remove the (2) cylinder air tubes [2].
Disconnect cable 36-3100 [1] and cable 30-30675 [2] from the bracket assembly.
Remove the:
  • Pallet-pool lifter solenoid valve assembly socket-head cap screws (SHCS) [1].
  • Pallet-pool lifter solenoid valve assembly washers [2].
  • The pallet-pool lifter solenoid valve assembly [3].
Remove the (2) cylinder air tube fittings [1].
Install the muffler [1] on the top air cylinder port [2].
Install the replacement pallet-pool lifter solenoid valve assembly from the kit [1] to the bottom air cylinder port [2].
Connect the main air-tube [1] to the replacement pallet-pool lifter solenoid valve assembly [2].
Connect cable 36-0675 [1] to cable 250 [2].
Change Parameter 747 PAL POOL LFT DN DWL to 3000 [1].
Reinstall the slider casting plate and cable carrier.
