TL - Steady Rest - Installation - AD0209
Service Home How To Procedures TL - Steady Rest - Installation
Recently Updated Last updated: 03/16/2023
AD0209
Applies to machines built from: March, 2004
- Jump to Section - 1. Introduction 2. Removal (2 steps) 3. Installation (2 steps) 4. Alignment (2 steps) Back to Top
This procedure tells you how to install a steady rest provision kit on TL-1/2 machines.
This procedure applies to the following service kits:
  • 93-1000277 STEADY REST MANUAL TL-1/2
Tools Required:
  • 3" (76 mm) Bar stock with a smooth finish, 12" (30 cm) long
NOTE: For TL-1 machines manufactured within 1/15/2023 to 5/15/2023, check the amount of bends the ballscrew cover has. If the ballscrew cover has only 3 bends 25-10677A, a ballscrew cover with 5 bends 25-10677B needs to be ordered to be compatible with the steady rest.
Removal
Do this procedure for a TL that has a factory-installed steady rest. You must remove the steady rest from the shipping position and put it into the operational position.
Warning: Before you move the Z Axis to the home position, make sure you move the steady rest out of its stowed position.
Press [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker.
Use an approved lock with an approved safety tag.
Attach a lift [1] to the steady rest.
Warning: The SR-5 steady rest weighs 75 lb (34 kg). Use a lift that has the correct capacity.
Find the screws [2] that attach the retainer plates [3].
Loosen the screws.
Turn the retainer plates. Do this until the retainer plates are clear of the edge of the the casting. This lets you remove the steady rest.
Move the steady rest to the middle of the lathe.
Lift the steady rest from the lathe.
Press [POWER OFF].
Warning: The SR-5 weighs 75 lb (34 kg). Use a lift of the correct capacity.
Lift the steady rest into the lathe.
Turn the retainer plates [3]. Do this until they are under the edge of the base casting.
Turn the screws into the retainer plates.
Tighten the screws.
Alignment
This procedure tells you how to align the optional steady rest. You must manually align the steady rest along the Z-Axis travel. The steady rest locks in position with a mechanical clamp. You can use the optional tailstock and the optional steady rest together.
Press [POWER OFF].
  • Turn the (3) blade lock screws [2] to loosen the blades.
  • Turn the (3) adjustment screws [1] to retract the blades.
  • Clamp the bar stock [3] into the chuck.
  • Do these steps to set the correct location for the steady rest:
    • Use this formula to calculate the distance from the end of the bar stock: diameter of the bar stock x 2 = location of the steady rest.
    • Put the steady rest at this location.
  • Use an indicator [4] to measure the outside edge of the bar stock.
  • Use your hand to turn the spindle.
  • Turn the adjustment screws [1] until the indicator reads zero while the spindle turns.
  • Tighten the blade lock screws [2].
