TSC-300 - Coolant Pump - Auto-Clean Coolant-Shield - Installation - AD0178
Service Home How To Procedures TSC-300 - Coolant Pump - Auto-Clean Coolant-Shield - Installation - AD0178
Recently Updated Last updated: 01/17/2019
AD0178
Applies to machines built from: December, 2014
- Jump to Section - 1. Introduction 2. Parts Required 3. TSC-300 - Coolant Pump - Auto-Clean Coolant-Shield - Installation (3 steps) Back to Top
This procedure tells you how to install a coolant shield. The coolant shield is installed over the pressure-relief valve of the Auto-Clean Coolant Pump. Perform this procedure when you have these (2) conditions:
  1. The Auto-Clean Coolant Pump was made before March 15, 2015.
  2. Coolant sprays out of the coolant tank.
Coolant can spray out of the tank if you have one of these conditions:
   •  The coolant level is low.
   •  A tool with a small diameter is used.
All Auto-Clean Coolant Pumps made after March 15, 2015 do not have this problem.
Parts Required
  • P/N 93-2279 DEFLECTOR SHIELD 300PSI PUMP
Press [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the Auto-Clean Coolant Pump [1] from the coolant tank.
Loosen the (2) 3/8-16 x 3 1/2 SHCS.
Install the coolant shield [1] into the assembly for the Auto-Clean Coolant Pump.
Put the coolant shield [1] between the mount plate [2] for the pump and the washers.
Torque the (2) 3/8-16 x 3 1/2 SHCS [1].
Refer to the Haas Fastener Torque Specifications.
Use the torque value for steel.
Install the Auto-Clean Coolant Pump [2] to the coolant tank.
