UMC Schrader Valve Upgrade Kit - Installation - AD0426
Service Home How To Procedures UMC Schrader Valve Upgrade Kit - Installation
Recently Updated Last updated: 03/02/2021
AD0426
- Jump to Section - 1. Introduction 2. Assemble the Schrader Valve (1 step) 3. Install the Schrader Valve (2 steps) Back to Top
This procedure explains how to configure the Schrader valve for the UMC-750SS B and C axes as well as the UMC-750 B axis in order to bleed the hydraulic brakes using the T-0062C tooling.
Refer to the B-Axis and C-Axis Rotary Brakes - T-0062C Bleed Instructions - UMC-750/SS.
This document applies to the following service kit:
  • 93-2956 UMC SHRADER VALVE UPGRADE KIT
The kit contains two Shrader valves [1] and three adaptor fittings.
Configure the schrader valve assembly as follows:
  • For the UMC-750/P B axis assemble the Schrader valve [1] with the fitting [4].
  • For the UMC-750SS C axis assemble the Schrader valve [1] with the fitting [2].
  • For the UMC-750SS B axis assemble the Schrader valve [1] with the fitting [3].
NOTE: Apply the thread locker onto the Schrader valve threads before installing it into the fitting.  Make sure that the  Schrader valve [1] and fittings [3] and [4] has the o-ring at the base of the thread.
This picture showing the location of the C axis bleeding port [1] and the B axis bleeding port [2] on the UMC-750SS rotaries.
The UMC-750/P B axis bleeding port location is the same as on the UMC-750SS.
Remove the plug [1] from the bleeding port.
Use the magnet [2] to remove the steel ball [3] out of the bleeding port.
Install the appropriate Schrader valve assembly [4] from the kit.
Torque the Schrader valve assembly as follows:
  • UMC-750SS C axis fitting tightening torque is 50 in-lbs.
  • UMC-750SS B axis fitting tightening torque is 40 in-lbs.
  • UMC-750/P and the UMC-750SS B axis fitting tightening torque is 100 in-lbs.
Note: Apply the thread locker to the threads before installing the Schrader valve assembly.
