Spindle Drawbar Force Reference Table - RD0067
Service Home Spindle Drawbar Force Reference Table - RD0067
Recently Updated Last updated: 04/10/2026
Spindle Drawbar Force - Reference Table
RD0067
Revision D - 04/2026
This reference document shows the recommended spindle drawbar force values for 20T, 30T, 40T, 50T & HSK spindles. A low spindle drawbar force results in significant clamp force loss typically caused by a crack or break in the belleville spring washer. To check the drawbar force, follow the Spindle - Drawbar - Force Measurement - VMC procedure.
 Note:  A loss of ~ 50% of nominal clamp force is an indication of this failure mode.
Note: As a drawbar wears in during normal use a slight decrease in clamp force is expected.  This is not an indication of drawbar failure.
Note: The 09-xxxx part numbers listed for the 40T and 50T spindles are the Spindle Drawbar Force Gauge Tool available through E-Commerce.
Refer to the Spindle - Drawbar - Troubleshooting Guide
20T Spindles - OM / CM Series
OM, CM Series
Spindle RPM Drawbar Force (lbf)
[Newtons]
Drawbar Pressure (PSI)
[kg/cm^2]
30K RPM >280
[>1245]
No Haas tool available.
50K RPM >280
[>1245]
30T Spindles - VF / VM
VF, VM Series
[Newtons]
Drawbar Pressure (PSI) for 09-0571
[kg/cm^2]
30K RPM 600 - 900
[2669-4003]
387-587
[27-40]
30T Spindles - DT/DM
DT Series
Spindle RPM Drawbar Force (lbf) Drawbar Pressure (PSI) for 09-0571
[kg/cm^2]
10K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
12K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
15K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
*20K RPM (Machines built after 5/20/2019) 920 - 1420
[4092-6316]
594-916
[41-63]
**20K RPM (Machines built before 5/20/2019) 675 - 775
[3003-3447]
435-500
[30-34]
* 20K RPM Spindles built after 5/20/2019 have the following part numbers: 30-12403, 30-12403A, 93-30-12403
** 20K RPM Spindles built before 5/20/2019 have the following part numbers: 30-11556, 93-30-11556, 93-30-11556A
40T Spindles - VF, VM, EC, UMC, and GM (3-AX) Series
[Newtons]
Drawbar Pressure (PSI) for 09-0572
[kg/cm^2]
7.5K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
8K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
8.1K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
10K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
12K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
15K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
18K RPM 1460 - 2300
[6494-10231]
942-1484
[65-102]
30T Spindles - DC Series
DC Series
[Newtons]
[kg/cm^2]
10K RPM  550 - 680
[2446 - 3025]
355 - 439
[24.5 - 30]
15K RPM 550 - 680
[2446 - 3025]
355 - 439
[24.5 - 30]
20K RPM 550 - 680
[2446 - 3025]
355 - 439
[24.5 - 30]
40T Spindles - DC Series
DC Series
[Newtons]
[kg/cm^2]
10K RPM 1322 - 1543
[5880 - 6863]
852 - 995
[58 - 68]
15K RPM 1322 - 1543
[5880 - 6863]
852 - 995
[58 - 68]
20K RPM 1322 - 1543
[5880 - 6863]
852 - 995
[58 - 68]
40T Spindles - DM Series
DM Series
[Newtons]
[kg/cm^2]
10K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
12K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
15K RPM 920 - 1420
[4092-6316]
594-916
[41-63]
40T Spindles - Gantry (GR) Series
Gantry (GR) Series
Spindle RPM Drawbar Force (lbf) Drawbar Pressure (PSI) for 09-0572
[kg/cm^2]
5K RPM 780 - 1400
[3470-6228]
503-903
[35-62]
10K RPM 780 - 1400
[3470-6228]
503-903
[35-62]
15K RPM 780 - 1400
[3470-6228]
503-903
[35-62]
40T Spindles - TM, MM, SMM
TM MM, SMM SERIES
[kg/cm^2]
4K RPM 780 - 1400
[3470-6228]
503-903
[35-62]
6K RPM 780 - 1400
[3470-6228]
503-903
[35-62]
10K RPM (SMM) 780 - 1400
[3470-6228]
503-903
[35-62]
15K RPM (SMM) 780 - 1400
[3470-6228]
503-903
[35-62]
50T Spindles - VF / EC
VF, EC Series
[Newtons]
Drawbar Pressure (PSI) for 09-0573
[kg/cm^2]
5K RPM 2810 - 4400
[12499-19572]
1813-2839
[125-196]
6K RPM 2810 - 4400
[12499-19572]
1813-2839
[125-196]
7.5K RPM 2810 - 4400
[12499-19572]
1813-2839
[125-196]
10K RPM 2810 - 4400
[12499-19572]
1813-2839
[125-196]
Haas HSK Spindles
Haas HSK-A63
[Newtons]
[kg/cm^2]
12K RPM 2835 - 4050
[12610-18015]
15K RPM 2835 - 4050
[12610-18015]
18K RPM 2835 - 4050
[12610-18015]
H-5AX HSK Spindles
HSK-A63
Spindle Type Drawbar Force (lbf)
[Newtons]
Push out (in.)
[Millimeters]
[kg/cm^2]
HSD ES789 2832 - 5170
[12597-22997]
.417 +.004/-0.0
[10.6 +0.1/-0.0]
145
[10]
HSK-F63
[Newtons]
Push out (in.)
[Millimeters]
[kg/cm^2]
HSD ES779 1731 - 3147
[7700-13999]
.417 +.004/-0.0
[10.6 +0.1/-0.0]
145
[10]
HSK-A100
[Newtons]
Push out (in.)
[Millimeters]
[kg/cm^2]
HSD ES511
10116 - 13038
[45000-58000]
.524 +.004/-0.0
[13.3 +0.1/-0.0]
