EC-1600 - Rotary - Troubleshooting Guide - TG0061
Service Home EC-1600 - Rotary - Troubleshooting Guide - TG0061
Recently Updated Last updated: 10/10/2025
TG0061
- Jump to Cause - 1. Introduction (6 steps) 2. Symptoms table 3. Oil Filter Troubleshooting (3 steps) Back to Top
This document will provide information ont he rotary unit for the EC-1600 for information on the EC-400/500/630 rotary please refer to the EC/VC Rotary - Troubleshooting Guide
For related inspection reports follow the link below. Be sure to download the correct inspection report for the correct machine. EA0283 for EC-1600.
Inspection Report List
1. Platter Assembly
2. Ring Gear
3. Brake Ring
4. Rotary Scale Assembly
1. Servo Assembly
2. Brake Booster Assembly
1. Ring Gear
5 Degree Indexer:
1. Platter Assembly
2. 5 Degree Face Gear
3. Clamp and Unclamp assembly
5 Degree Indexer:
1. HPU Motor and Pump
2. Servo Motor Assembly
3. Accumalator and Solenoid Assembly
5 Degree Indexer:
1. RING GEAR 220 TOOTH
2. PISTON ADAPTER EC-1600
Symptoms table
Symptom Probable Cause Solution
5.103 A-AXIS SERVO ERROR TOO LARGE on the 5 DEGREE INDEXER Misalignment of the face gear to the platter.
Adjust the tool change offsets so that the load is no longer high when clamping.
Please refer to the tool change offset procedure for further instructions.
5.108 A-AXIS SERVO OVERLOAD  on the 5 DEGREE INDEXER
Load is very high when the platter clamps
A-Axis indexer not clamp caused by oil leakage Oil filter is not tightened enough causing the leak to come from there. Replace the oil filter, make sure it is properly tightened.. Refer to the Oil filter Troubleshooting section for more information
Remove the sheet metal covering the HPU system on the front of the table.
Clamp the system by switching from handle jogging X-axis to A-axis.
Visually inspect the system and see if there is any leaks present.
If the leak is coming from the oil filter make sure it is fastened to the housing. If it is not inspect the oil filter housing.
